2011 REAR BRAKE UPGRADE/REPLACEMENT
626
1,058
Wisconsin
Over the winter I want to swap out/upgrade my rear brakes. I have the GT500 conversion on my car however I might be 5 plus years old. I really dont know. Question is...
Should I stay with this set up and just buy new calipers or is there a better 2 pist upgrade kit to buy. Again I want to replace the calipers as well as the rotors and pads.
FYI I will also be doing to 6 pis Brembo upgrade from my 4pot this winter as well.
Thank you for all the help!
Andy
ArizonaBOSS
Because racecar.
8,730
2,734
Arizona, USA
IMO there is not a lot of value to trying to do much differently in the rear. I would just look at the pads that are coming out of there and see if there is any radial taper wear indicating that the caliper bridge may be flexing, if so, replace the caliper(s). But factory replacements are relatively inexpensive so no big deal.
I use the factory calipers in the rear on my race car, FWIW.
626
1,058
Wisconsin
Do I just buy 12-14 gt500 rear calipers then? Seems oddly hard to find on the good old web.
I bought the adapter so I can run a larger rear rotor, had frozen rotors set me up with pads and rotors to match the 6 pistons up front with this setup ( adapter on ebay ). I did just buy the temperature brake paint ( something like 7 colors ) so I can see what temps I run front\rear and adjust from there.
1,166
1,164
Lenoir City TN
If you already have the 2013-2014 Shelby GT500 set up on the rear their isn't much left to do. If you need calipers rebuild the factory calipers or buy new ones from Ford. Rebuilds do not hold up to the heat of track use. I went through 2 sets of Napa Eclipse premium rebuilds on the rear in a month or two. The second set started leaking after one track weekend. I bought new OEM from the local ford dealer and they have been on the car for a year with no issues.
626
1,058
Wisconsin
Nice, any chance you can hunt a part number for me?
626
1,058
Wisconsin
7,556
5,291
Yep. The upgrade is a different bracket between the axel and the caliper bracket and the larger rotor. You can simply change the axel to caliper bracket. You may have to relieve (Grind) a bit of metal away to clearange the caliper bracket. A small die grinder or grinding wheel should work. It's been a few years since I modified mine. The single piston caliper is all you need in the rear. As front braking increases, demand for rear braking does not increase.
626
1,058
Wisconsin
Ok then when shopping for new rotors, do I buy 12-14 gt500 rotors then? I know you need to do that for the 6pis upgrade.
1,166
1,164
Lenoir City TN
I am confused. The thread is about rear brake upgrade and this post is referring to 6 piston upgrade which is front brake upgrade. Which are you doing?
1,166
1,164
Lenoir City TN
Rear sorry. Wanted to know what rotors I need to buy once I get new calipers. The gt500 calipers.
If you are moving to the 13-14 GT500 set up with the 13.8" rotors using the stock calipers you need to order the late 13 or 14 shelby GT500 rotors. There was an in year change so there are two rotor sizes listed for 2013. I usually order for the 2014 to make sure I don't get the small ones.
160
110
NJ
Is there really any benefit (besides looks) to upgrading to a 13/14 GT500 rear rotor? Seems like I've read as much negative as positive experiences, especially when using the adapters.
334
353
It reduces heat and helps preserve rear brakes and axle seals on track especially if you are running with stability control on. Like you I don't love the looks of the adaptors. They may be fine but I would take the time to remove the axles and install the proper Ford brackets, do the job right and do it once no second guessing.
Other than heat management I don't recall any significant change in braking performance either pro or con.
You can find cautionary posts about bigger rear brakes throwing the balance all out of whack but I never found that to be the case. Just choose pads wisely as always.
