2012 Boss needs new cats
I have a 12 Boss that has a plugged cat according to the dealership. Looking for suggestions on replacements.
Drive train is all stock except I added the track key.
Car is street driven only.
OEM is $1200 installed.
I'm assuming there are aftermarket cats that are equal or better in quality, fit, and performance.
Thanks,
Dave
Bill Pemberton
8,496
8,493
Blair, Nebraska
I would just replace with a set of high flow cats as the issue will be easily solved. Keep in mind most Auctions require a Dealer to divulge if a car has had cats removed. This will affect your resale since Dealers have the question listed on their purchase forms and they will deduct a princely sum if replacement is needed. This is partly due to the cost of the cats, but also because so many exhaust systems are modified that getting it back into compliance is even more costly. Just a word of caution because this is common even in States that do not require emissions testing.
PS - Google high flow cats and you will be shocked at the number available. Don't get the dirt cheap ones , but you will find plenty of choices. Check ones at American Muscle , CJ Pony Parts, etc. as you should be able to get a decent set for 200-500. The cheap ones are that for a reason and the OEM ones are just off scale price wise. Good luck.
112
Autocross
Southern Illinois
Luckily the previous owner of my car gave me the full stock exhaust from manifolds , cats, and brand new gt mufflers that were maybe 6 months old.
