302S LCA (M-5649-S) NVH
380
2
Installed in the 302S LCA, with relocation brackets and T springs.
Took the car out for the first few drives this weekend. I notice a clunk, or rattle noise from the rear suspension over bumps. I don't notice any other noticable NVH. Is this normal? Everything looks and feels tight and I have re-checked everything with a torque wrench today.
Yep. The M-5649-R1s with urethane bushings are quieter but presumably flex more.
380
2
OK, thanks. I don't really mind the noise so much, it's mostly a track day car at this point anyways. I just wanted to make sure I didn't goon something up with the install of all of these parts at once.
PeteInCT
#LS-378 - So many Porsche's, so little time....
2,848
14
Connecticut
steveespo said:
Mine rattle over bumps too. Suprisingly we installed them in Pete in CT's car last spring and they didn't make noise.
Steve
That's cuz I'm special. ;D
Everything behind my seats is open and bare metal. I hear so much stuff coming from the rear of my car that I just ignore it all as long as it sounds the same as my previous run.
I am thinking of getting the FRPP LCA with polyurethane bushings, anybody has first hand experience with them? Function and NVH
PeteInCT
2,848
14
Connecticut
I have them. Big improvement. Do rears also with relo brackets.
-Pete
TMSBOSS
7,556
5,291
Illinois
I have them. No issues.
One note. Ford did nave supplier issues where the wrong arm was packaged and shipped. I received a set. All you need to do is measure the ends to ensure you don't receive an older/incorrect set. The ends should be different sizes, about 1/2 inch wider on one end.
