While I am making the switch to front coilovers, replacing the hubs and switching to a 35mm adj swaybar with shorter end links, I am thinking about what route to go with the control arms. I will be running square 18 x 11 and an 18mm rear bar. The little track time I have had with the car was with a 22mm rear bar and I did have some push in low to moderate speed turns. Would a taller ball joint, bump steer kit and some toe be enough to get the front end in line or would it be worth the investment to go with a completely different control arm with the previously mentioned upgrades? The car will see very little street use with mostly short drives so I am not worried about NVH.
