Aftermarket Recaro Racing Seats - No Airbag Light
46
38
Autocross
Arizona
Hey guys,
I'm looking at installing some cloth Recaro Pole Position seats in my 2013 Mustang GT. I've done a lot of research on making sure I don't get an airbag light after everything is fully installed, but still have some questions I cannot find answers to. I'm hoping one of you that has installed aftermarket seats with no side airbags in the aftermarket seats can help me out here. Note: I'll be using the stock seatbelts for now as this car is my daily driver and my weekend fun car.
Here's what I understand so far (correct me if I'm wrong): I do not have to disable the seatbelt chime as I'll be using the stock seatbelts. On the driver side, I'll be removing the stock harnesses from the bottom of the stock seats and putting them under my Recaro driver seat. I'll be plugging in a 2 ohm resistor to the yellow airbag plug on the harness to avoid throwing an airbag code. I'll also be plugging in the seatbelt sensor. And the seat position sensor which I will wrap with electrical tape and then leave on the floor (secured with zipties) so it doesn't ground itself to anything.
On the passenger side, I'll do all the same things as I did with the driver side. Additionally, I'll be drilling the rivets out of the OCS module on the stock passenger seat and will be plugging it into the harness under the Recaro passenger seat. Lastly, I will need to remove the bladder from the stock passenger seat and connect it to the harness under the Recaro seat as well. I'll likely be wrapping the seat bladder in between 2 soft plates of something (like a burrito) to put constant pressure on it, so the front passenger airbag will be always engaged. Here's where I cannot find any information:
With removing the seat bladder from the stock passenger seat, where is the bladder located in the stock seat? Do I need to take apart, and pretty much ruin my stock seat, to remove it? Or is it just removed by unscrewing some screws and nuts? Pictures would be greatly appreciated if you have any, for me to visually see where the bladder sits on a stock '13-14 passenger seat.
Also, to my understanding, if I follow all of these steps, I should have no DTCs, warning lights, or any codes and my airbag light should be off with the front airbags fully functioning, correct? Am I missing anything in these steps to ensure no airbag light or thrown codes?
This is my first time doing a mass amount of modifications on a car, including aftermarket seats. Thank you so much for any help!
The OCSM bladder shouldn’t be mounted in a manner that tricks it into thinking someone is always there. It should be mounted between the seat frame and the seat pad. If you’re going to attempt to keep the airbags functioning properly you’ll also want to re-cal the OCSM in the passenger seat using IDS
46
38
Autocross
Arizona
2
1
Autocross
North New Jersey
Hey guys,
I ended up picking up the resistors for 05-07 Mustangs, removing the resistors in the plugs, and soldering on 2ohm resistors. Worked like a charm and I love my bucket seats.
Were your original seats the premium package seats by chance? I'm also looking into getting aftermarket seats, and I was curious if there was anything more that needed to be done with a premium package seat harness to avoid any and all lights/DTC's. As far as I can tell, the only component difference is the seat heater which doesn't sound like it could affect the airbag system but maybe the climate control? Any insight will help. Thanks!
46
38
Autocross
Arizona
Mine were the premium package seats. I had to disconnect the heat seater connection of course. The most difficult part of the seat heater was on the passenger side, where I had to remove and dismantle the coils for the seat heating to get to the weight bladder, which was mounted above the seat heating components. It wasn't difficult, just a bit time consuming. Any other questions, let me know.
2
1
Autocross
North New Jersey
Okay makes sense, thanks for the quick reply!!
