- Thread starter
- #41
God that thing is huge. Didn't know they made 960's anymore, I only found 948's.
I'm in the middle of mounting my 948 now. I have two threaded bosses on the front passenger side of my radiator that the Setrab bracket fit nicely on with only a bit of filing. Mounted sideways for straighter plumbing runs. Doing -12 for lowest pressure drop. The fittings and hose are huge but I think will be worth it. If you use the Setrab sandwich plate it has M22 ports so you can do full -12 fittings and lines without any -10.
Also the nomex honeycomb is amazingly tough and light. Even just for protecting the cooler and radiator for this fab phase its saved a bunch of dings.
Ducting is going to be a pain but worth it. Was good for 30* lower CHT on my Ecoboost.
Please re-read the NASA rules regarding Fuel Cells (how the in-car tank will be treated). You're going to need a bulkhead. The lines themselves do not need to be contained within the bulkhead (if they are braided stainless or better), but consider your own safety in the case that a fitting becomes compromised somehow, you don't want pressurized fuel spraying onto you or up into the driver's area in-general.
It's cheap insurance. @captdistraction has a number of photos in his thread of the containment "bulkhead" that we fabricobbled together in his garage that will meet the intent and needs.
1. There should be a solid bulkhead completely separating the fuel tank, fuel pump, fuel cell, filler neck hoses, and vent lines, from the driver compartment.
Already done and ordered! I did some more reading up yesterday after an initial quick glance at the NASA ST rules did now show anything. I finally found it in the CCR - Club Codes & Regulations
Edit:
@captdistraction got any pics of your bulkhead? Can't locate any in your thread and I think last time I've seen your car it wasn´t installed yet.
OneDrive
1drv.ms
I see nothing bothersome here.Time for a sanity check: Do these welds look fine or will I have to get anything adjusted?
I will be dropping off some things at the welder next week (oil pickup support etc.) so now is a great time to gather some feedback.
@Fabman @captdistraction @honeybadger
View attachment 71830View attachment 71831View attachment 71832View attachment 71833View attachment 71834View attachment 71835View attachment 71836View attachment 71837View attachment 71838View attachment 71839View attachment 71840View attachment 71841View attachment 71842View attachment 71843View attachment 71845View attachment 71846
Yes I know, I’m on my iPad and it’s not post friendly as a desktop.Not mine sadly. That is what Chris did on his.
