Bill Pemberton
Go for it, Mad Layman who is the Slayman of the Cayman!
Cooling is huge. I ran every race last year and several test days on one set of pads.Air to the calipers is such a cheap upgrade and so often pad wear is minimal because folks simply do not have enough of the free stuff blowing over the calipers, rotors and pads!
The car looks amazing….did you put tunnels in your splitter?Got some pics to day from the weekend. Lots of Krauts!
Got something in my teeth!
Too much wing angle... it was for the wet track, should have put it back to near zero when it dried out. Splitter is much lower but the butt is pressing down the rear and lifting the front
what do you call a pack of Caymans on land? ..... a Bask!!!
Youngsters in German cars vs Old guy in a Mustang. GT3 in first place
Thanks!! No not yet, but thinking about it.The car looks amazing….did you put tunnels in your splitter?
Do it...and the bigger the better. Or I should say, the more efficient tunnels the better.Thanks!! No not yet, but thinking about it.
There's me 3rd from the left wearing the Michelin banner.Got some pics to day from the weekend. Lots of Krauts!
I ran those last year, they’re pretty small. AJ Hartman aero has some really great units. I put a set in my car for ‘22.Professional Awesome Splitter Diffusers - Pair - Professional Awesome Racing - Time Attack and Downforce Specialists
Revised design for improved strength and the same great performance! Designed and optimized using CFD to ensure the best possible performance. Once installed, diffusers create a low-pressure transition zone that greatly increase the downforce potential of any splitter. Designed to be installed...professionalawesome.com
These seem very affordable...
BTW, are you using the MMR inverted tensioner bracket?faulty secondary timing chain tensioner.
hmm.... interesting will do some checkingBTW, are you using the MMR inverted tensioner bracket?2011-2017 5.0 Coyote MMR Billet Secondary Tensioner Bracket [467893] - $69.99 : Modular Motorsports, Home of the worlds fastest Fords
Modular Motorsports 2011-2017 5.0 Coyote MMR Billet Secondary Tensioner Bracket [467893] - Here is a great new "PATENT PENDING" part that MMR spent most of last year testing. Ford is notorious for tensioning chains on the wrong side and the 5.0 coyote was no different. Long story short the...www.modularmotorsportsracing.com
Couple things to consider on this bracket. Ford made a running change on the secondary tensioners and all of the new ones are shorter in length than the originals. This MMR bracket won’t work with the new OE design. I talked to MMR about it, they confirmed it wouldn’t work and said they were working on a revised bracket. Not sure if that’s out yet - I would confirm before ordering if you have the shorter tensioners.hmm.... interesting will do some checking
They look great, but they are a bit pricey for me right now. Thinking that a 3D printer would cost me about the same.I ran those last year, they’re pretty small. AJ Hartman aero has some really great units. I put a set in my car for ‘22.
Custom Splitters - AJ Hartman Aero
ajhartmanaero.com
