KNS Brakes
Supporting Vendor
292
20
Cary NC
We have a variety of Performance Brake Fluids in stock. Below is a full list of our current selection.
Ate TYP200 Brake Fluid - 1L
ATE TYP200 High Performance Brake Fluid exceeds all DOT4 standards.
  • Dry Boiling Point 536°F
  • Wet Boiling Point 388°F
  • Each can contains 1 L which is enough to flush most vehicles
  • Recommended for hydraulic clutch systems also
Motul DOT 5.1 Brake Fluid - 500mL
Motul 5.1 High Performance Brake Fluid exceeds all DOT3 and DOT4 standards.
  • Dry Boiling Point 522°F
  • Wet Boiling Point 365°F
  • Each bottle contains 1/2 L, most vehicles require 1L or 2 bottles.
  • Recommended for hydraulic clutch systems also.
Motul RBF600 Brake Fluid - 500mL
Motul RBF600 High Performance Brake Fluid exceeds DOT4 standards and is primarily a racing brake fluid.
  • Dry Boiling Point 594°F
  • Wet Boiling Point 399°F
Motul RBF660 Brake Fluid - 500mL
Motul RBF660 High Performance Brake Fluid exceeds DOT4 standards and is primarily a racing brake fluid.
  • Dry Boiling Point 617°F
  • Wet Boiling Point 400°F
Castrol SRF Racing Brake Fluid - 1L
Castrol SRF is the world's most recognized racing brake fluid and is used in the most demanding racing conditions.
  • Dry Boiling Point 590°F
  • Wet Boiling Point 518°F
  • Each bottle contains 1 L, most vehicles require 1 liter for a full flush.
PLEASE NOTE - THIS ITEM IS ON BACK ORDER UNTILL FURTHER NOTICE
Brembo HTC-64T Racing Brake Fluid - 500mL
Brembo HTC 64T is a high temperature racing brake fluid.
  • Dry Boiling Point - 635°F
  • Wet Boiling Point - Not published
  • Do not use in brake or clutch systems containing magnesium parts.
Ferodo Super Formula Racing Brake Fluid
Ferodo Super Formula Racing Brake Fluid a high temperature racing brake fluid. All Ferodo fluids are of Glycol based ether composition, and are suitable for brake and clutch use.
  • Dry Boiling Point - 626°F
  • Wet Boiling Point - 392°F
AP Radi-Cal R3 Racing Brake Fluid
R3 is compatible with all hydraulic brake systems designed to conform to S.A.E. J1703 requirements, which means it is suitable for both street and track use.
  • Dry Boiling Point - 608°F
  • Wet Boiling Point - 399°F
AP Radi-Cal R4 Racing Brake Fluid
R4 has been explicitly designed to perform better than any other product at the extremes of heavy duty braking performance. R4 is NOT compatible with hydraulic brake systems designed to conform to S.A.E. J1703 requirements.
  • Dry Boiling Point - 644°F
