Brake Pad/Rotor Upgrade for track days
6,550
8,202
6,550
8,202
Here's a great tip:
When you buy new rotors have them cyro treated.
I used to get 2 races out of a $1300.00 set of rotors. Now I get a full season.
Costs 125.00 to have them treated.
Money in the bank.
5,239
4,228
Once I switched to Castrol SRF never had a brake fluid failure again.... But ATE left me traumatized!! Its wet boiling point is low, its about 130 deg less then a a Wet SRF. It gave me by far the scariest experience I have had at the track. Brake pedal to the floor entering a 90 deg curve at 160mph, it took me about a year to brake late again.
If you use ATE make sure its fresh out of the can and you change it after every track day.
48
41
Fort Worth
Here's a great tip:
Money in the bank.
Do you get them cryo'd from your vendor or do you get that done yourself? I tried googling it but haven't found where one would get rotors processed.
How long does the SRF last? I've been running DOT4 and changing it often and thought SRF was the same just more "pro level" high temperature stuff.
6,550
8,202
There is a heat treating place in nearby Hayward that offers cryogenic services. Costs about 125.00/pair.
you want a brake fluid that has at least a 600 degree dry boiling point. Bleed it before every event.
8,492
8,487
Best info listed is to " Bleed " the brake lines before every event! I have recommended this for years to friends starting racing, Time Trials or HPDEs because years ago the Pro Racers and Factory Engineers told me, the autocrosser flipping over to Time Trials, to do this religiously. Nice to hear it from our NASA National Champ, Fabian, and one of the things that is relatively inexpensive, yet so important ----- the pony can gallop , but she has to whoa when you need her too!
6,550
8,202
Fabian? Lol.
7,547
5,275
What sold me on bleeding brakes between events was the color of the fluid in the caliper. The first few pumps of the pedal brought out a darker fluid. I assume this is burned fluid. I bleed the caliper until the fluid runs clear again. Usually 2-4 iterations.
