Brembo 14” Rotor Ring interchangeably
I have 2-piece 14” brembo rotors with the OE Boss 4-piston calipers. These were purchased from Kohr at their moving sale, good price from Dean.
Question is can the blank rings be swapped with slotted rings and fit without spacers?
P/n for current 2-pc rotors (or only the hat?) is 16.C260.10 3L11 (see pic)
Kohr web store still shows Brembo slotted rings BRE.09.9306.21 and BRE.09.9306.11
Rotor Sizing is the same 355mm x 32mm but is the offset the same?
PN 16.C260.10 3L11 is only for the hat.
Offset is determined by the hat not rings.
If the ring bolt circle and ring bolt number is the same, (along with diameter and thickness) it should interchange. You can confirm with Kohr.
