cloud9
Gary
OK, we all know the GT350 came in a little heavier than we hoped for and there appear to be limited opportunities to lighten it up, but I thought it would be helpful to create a repository of various weight adders and subtractors for the mods we are making. (e.g. a roll bar will add weight, but removing the stock rear seats and belts subtracts weight. Changing from the stock wheel/tire combo will also likely change weight)
I will start with the limited items I have delved into and welcome all others to contribute. I will keep this first post as a running list as other members post their findings.
Watson Engineering 4 point roll bar: +61 lbs.
Watson rear seat delete carpet kit: + 13 lbs.
Remove rear seats, brackets and belts (GT350): - 39 lbs.
Sparco Race seat/side mounts/slider: TBD
Momo Race seat, mounts, hardware and 6 point harness: 37 lbs.
Remove stock driver seat: -49 lbs.
Remove stock pass seat: -46 lbs.
06mach1's jacking plates: +4 lbs.
OEM GT350 Rear Wheel/Tire: 62 lbs.
OEM GT3530 Front Wheel/Tire: TBD
OEM GT350R Rear Wheel/Tire: 47 lbs.
OEM GT350R Front Wheel/Tire: 46 lbs.
Remove trunk liner: - 4 lbs.
Remove flat repair kit: -4 lbs.
Front GT350 rotor: 30 lbs
Rear GT350 rotor: 18 lbs
@Black Boss
@Black Boss
