I've been taking my 05 GT to the track for about a year and I keep blowing out the seal for the drivers side rear caliper. I've tried everything I can think of:
Is there anything else I can try / check? The only thing I've got left is to try removing ABS using a delete block. I'm about to change the caliper for the seventh time (thank goodness for "lifetime warranties").
- New calipers, remanufactured calipers that have been tested, replaced bolts, caliper brackets, the works
- Removing the pin from the pad in case it's not aligned properly
- More thermal grease, less thermal grease, better thermal grease
- Different pads (Carbotech XP8, Carbotech XP10, G-Loc)
- GT500 14" conversion
- Removing the dust shields
- Checked to make sure it's plugged into the right spot on the ABS distribution block
