Ford Racing front hub question
Norm Peterson
Corner Barstool Sitter
939
712
a few miles east of Philly
I have 'clicker' torque wrenches in 100, 250, and 300 ft*lb and a little clicker (250 in*lbs). Beam-style torque wrenches in 150 ft*lb and 150 in*lb that can't go out of calibration without showing visible damage.
From time to time I have checked the 100 and 250 ft*lb wrenches against the 150 ft*lb beam torque wrench I've had since the 1960s.
Norm
TMSBOSS
7,556
5,291
Illinois
Our local tire shop bolted wheels on my Boss. I took it home and checked the torque. All were loose. I saw them use a torque wrench and gave them the torque spec. I let them know all were loose and they should have their wrenches checked. That was news to them. Got a call about a week later. They threw out their old wrenches since all were 10-18% LOW. Have your stuff checked guys. Many of the mobile tool trucks have the ability to check on the spot. I replaced my Craftsman a few years back. I bought CDI, they build the Snap-on wrenches now.
6,400
8,290
a lot of those guys use a "torque bar" for lack of a better term. Basically, they are the extension that the socket mounts on, they come in different colors for different torque settings.
I prefer the "clicker" type, but when setting bearing preload on a pinion bearing the beam type works best.
and don't forget to "unwind" those clicker wrenches so the spring won't take a set when you're done
TMSBOSS
7,556
5,291
Illinois
I have a set of the torque bars. I have not had issues with them....just hard for me to trust them. I always torque after. Preloads and clickers don't mix well. Have seen it done, don't like it. Clicks below load and does not click above load. Nope, don't like that.
6,400
8,290
Yep, mostly for production type shops, not race car related
