FR500S ABS Module Questions
304
380
CA
Hi Everyone,
I have a 2008 mustang that is primarily track use. I run 200tw tires in the 295-315 width range, S-550 6 piston brembos up front. I have recurring issues with engaging ABS.
I am thinking of adding the FR500S ABS module to my car to increase my confidence in the brakes.
Does anybody know where I can find one of these? Is installation plug and play? Do I need any other supporting parts?
Note, I am referring to the 2005-2009 FR500S ABS module, not the 11-14 302r/s ABS module. There is lots of great info here about the 11-14 module but I haven't seen much for 05-09 FR500S one.
Thank You,
I don’t think you’ll be able to find them anymore. Long discontinued. Another option to ponder is converting to 11-14 ABS. I have heard it can be done on our 05-09 cars. Likely results in a Christmas tree dash, but if it’s a track only car you may not mind. Plus if you convert, you can then swap to the 302S/R module as well
179
67
ny
I have 4 fr500c abs units 2 new 2 used.i emailed ford racing on clarifying units.
New 1 750$ used 450$ chris
179
67
ny
These units came from a race team who ran 5 fr500c and boss 302r in imsa. They were given to teams directly.These were NOT sold thru ford racing.
All units or boxes have prototype and research tags on them.
I was emailing ford racing to get more specs on units. All are from supplier TRW.
Chris
179
67
ny
These are complete units pump,distribution block and module and bracket.they are all face plug in not 90 degree boss style.
pictures
179
67
ny
Well…looks like I stand absolutely corrected, ha! I’m curious now.
@TA28 thanks for posting this up
@SMGDHG if you go this route let us know how it turns outOr we will cross paths up here at a track day sooner or later.
No you are right these are gone like the dodo bird. Not made period. What I found was a race teams inventory. Some nib some used.
I wanted ford to explain differences between
M-2353-b and m-2353-c or CA units.other than obvious modular cars use front mount plug and boss cars use 90 degree side mount for the plug. The fr500c and boss302s and R used same brake packages? So I doubt it's that.
And the B in last prefix I also doubt meant bracket? But?
Chris
M-2353-A - FR500S module
M-2353-B - Boss 302S/R module with entire distribution block
M-2353-C - Boss 302S/R module-only (Original programming)
M-2353-CA - Boss 302S/R module-only (Updated programming)
M-2353-D - FP350S module with entire distribution block (the only one currently in production)
