- 870
- 503
I stand corrected. I would then use the above with a CJ pump or an OEM pump with billet gears swapped in.
With the correct pickup it does. For 5.0L applications use M-6622-M50RR pickup tube.5.0 COYOTE STYLE ROAD RACE OIL PUMP PICK UP TUBE
5.0 COYOTE STYLE ROAD RACE OIL PUMP PICK UP TUBE|Ford Performance Partsperformanceparts.ford.com
we know the pain Chris. sorry, but just when things are going good.............I'm looking at that tube, oddly its so different than the 5.2 tube, no partial directional blockoff on the screen - some rough mandrel bends. I thought about buying one and cutting/welding the two together to make a halfway workable tube
At that point why not grab a OEM GT500 tube and pump and modify that to work with the FP350S pan. Or sell it all and go buy an expensive dry sump to break some inexplicable way
Have you called Bill at Daley? I think he'd help settle a lot of fears for ya'. He's really knowledgeable and helpful (at least in my experience).I'm looking at that tube, oddly its so different than the 5.2 tube, no partial directional blockoff on the screen - some rough mandrel bends. I thought about buying one and cutting/welding the two together to make a halfway workable tube
Chris 5.2 Predator blocks can certainly be honed for ring fit. My builder Chris Holbrook did just that to custom fit the piston rings on my shortblock. As for overbore you cannot go beyond.005" but the blocks are relatively cheap, or they can be sleeved. With the likelihood of failure before being worn out, most blocks suffer some damage that warrants replacement anyway.So the tube is ordered, along with a GT pump housing, a GT500 pump housing, and a GT500 pump tube (1" vs the 15/16" $200 FP350S junk). Hopefully between all of that I can come up with a solution that works.I'm also getting the crank scraper ordered, either way I'll use one of those on whatever I build.
As far as the hardware, not much good news: the block needs a .005" overbore or so - which means a custom piston (its already at 3.641"), unless I find a different piston. Mahle can make them for me, but is $1800 and 16 weeks out.
Otherwise can abandon the block (I might have it honed and sell it to someone who does want to mess with all of that). If I did that, likely would look at the 5.2L block, but I already have concerns about how sloppy ford is with tolerances since those cannot be honed on the bores. If I go that way, looks like you need a different crank (93mm vs 92.7mm)
The current race-prepped crank is to be magnafluxed, but the snout wear is an concern. The rest of it might polish up ok. Heads are still a question mark, but likely a valve job, guides, seals, springs plus whatever is needed on the cam bores. Cams can be polished, they're not that bad (I could just replace the exhaust cams since they're inexpensive and the intake cams look fine).
Looking at another used engine here soon, but its unknown, been on a stand for ages with a broken head. Its charity, so I can't turn my nose up, but the hope is I can hobble something together out of all of it to limp by while I figure out a longer term solution. I forget, but there was once something fun about this sport - I just don't remember exactly what, its been so long
I ended up making an album of all the pictures related to teardown - nothing curated but reference for me: https://1drv.ms/u/s!AlYNJ_4Or1Yc6pYX5WI2uBZgSySjaw?e=NihTJ0
Not that I have the ability to measure it accurately either way, but question on the cam-to-cam-bore clearance notes above: Are those "two-sided" (diametrical) or "one sided" (radial) values?
Just more curiosity here, not sure if worth rabbit-holing to find out, if you don't already know.
