GT350 Torque settings
Bumping this since it was helpful for me. Also I figured I would add what I believe to be accurate for our cars:
-Rear knuckle to lower arm bolt 203 ft lbs or 275 nm (21mm socket)
-Rear knuckle to toe link bolt 129 ft lbs or 175 nm (18mm socket)
-Rear knuckle to upper arm bolt 76 ft lbs or 103 nm
I couldn't find this information anywhere else, so I used the GT350/GT half shaft install instructions to pull this information.
Source: https://performanceparts.ford.com/download/instructionsheets/FORDINSTSHTM-4130-M.PDF
30
3-5 Years
Bay Area, CA
Thanks! So, 14 ft lbs for the front caliper bleeders and 10 ft lbs for the rear caliper bleeders is confirmed. I confirmed the fronts/rears with someone that has a shop/repair manual.
Wonder why the torque spec is less for the rears. It's the same size bleeder.
No problem! That's where my screenshot is from as well. I purchased the 2016 service info CD.
you’re not reading it right, its 16 nm or 168 lb/in....dont break them off
