Help - do I have these BMR a arms set for "max caster?"
Duane Black
Curbs go brrrppp
546
386
Durham, NC
I'm trying to do maximum caster, camber, and set the toe to 0. with that in mind, with the rear of the arm pulled full towards outer edge of the car, as pictured, is that maximum caster or minimum? Thanks!20211101_163210.jpg
Fabman
Dances with Racecars
6,370
7,863
I'm trying to do maximum caster, camber, and set the toe to 0. with that in mind, with the rear of the arm pulled full towards outer edge of the car, as pictured, is that maximum caster or minimum? Thanks!View attachment 69745
Yes.
However, I must ask you if you have the arms with the rod ends in the front or the bushing type.
If its the rod ends you are free to adjust away. If its the Bushing type I would be very careful about moving them very far from center as it could put the front bushing in a bind and these arms are known for breaking there due to angular loading/deflection of the front bushing under braking and cornering forces.
Putting it in a bind in steady state would compound this condition.
Fabman
6,370
7,863
This is a highly stressed component, particularly if you are running big brakes, slicks or sticky tires and performing threshold braking. Notice the rusted area, and then the fresh metal in this break. This tubing has been cracked for some time. Cracks will generally propagate from or along the edge of a weld. Generally, a good clue that a part is cracked, is by finding a hairline crack in the paint or coating. Once in a while. a crack may be sub-surface, and give no clues.
NDT inspection techniques, such as x-ray, eddy current, and similar inspection techniques will identify sub-surface cracks. After one or two track events, I put my car on the lift and perform a detailed visual inspection of the underside, giving special attention to the high stressed areas, and looking for any fasteners that might have backed off or failed.
Note, that BMR has since redesigned this lower arm, and has now made it available. Hope this helps someone!
