Update, this year had multiple sessions at Road America and Autobahn tracks and the cooling fight continues The following is only slightly scientific, which kills me - unfortunately, track time for running true A to B’s and garage time for gaging installs are my constraints. Huge kudos to those on the forum who have good data – thank you.
Vehicle: 2012 GT manual 3.73, Ford Performance radiator & high speed fan and Setrab 660 Oil cooler w/ setrab thermostat sandwich plate, oil temp gage pre-cooler and coolant temp is from OBD II (inferred), boss 302 lower fascia/small splitter, sct 93 octane tune
Road America – early spring, outside temps near 50F, end of the session oil temps peak 250F (pre-cooler, calcs say should drop 50 to 90F depending on correction factor for airflow and oil/air temps), coolant temps (inferred) near 240F (gage straight up). Good news, oil temp looked good, bad news coolant temp improvement not a stepped improvement
Road America – later spring, temps high 60’s by afternoon, end of session oil temps 255F, coolant temps now the problem getting up to 245F - borderline; had ready to go a AM billet grill (p/n 41124) and outside surround bezel from Rockauto (p/n FO1210105) just in case. Swapped grill between – knocked about 15F off the coolant temp, oil temp was the same. Was able to push the car with coolant temps getting up, but manageable.
Autobahn – 70F, coolant temps started to get high late in sessions, but with some easier laps was manageable.
So far good news on oil temps, coolant temps still a pain when outside temps getting higher
Now the real challenge – Gingerman, 94F air temp, 60%+ humidity, the track has a large portions of the lap in 4th gear higher rpm. We are back to the world of pushing two hard laps and coolant temps in the red (245F+), oil temp peak in session peaked at 265F pre-cooler. Back to the coolant temp issue, but oil temps great.
Open to additional options, but here are my thoughts on next steps:
- Short term
Take out the AM billet grill to increase airflow
- Remove weather seal at the back of the hood to give some flow out of engine bay (although small)
- Go to back to stock program, maybe the SCT tune is a bit leaner at high rpm increasing temps
- Other options/questions:
- Short term
- Creating an airbox, still have the air conditioning condenser, so factory side box is still in place – anyone have success fully boxing and improvements?
- Improved radiator – should have enough capacity, but others had better success with different radiators, how much of an improvement? Is it because of more restriction, i.e. does the water pump cavitate at high rpm causing flow issues and a multi pass puts more restriction helping decrease pump efficiency?
- Could move to distilled water and water wetter set-up in the summer currently 50/50 boring HDPE folk? Was trying to avoid keeping with the street able car that is a robust track day car. (the coolant chemistries are critical for corrosion and lubricants in the system which is the other challenge)
