Hello,
I was curious to know if anyone here uses one of these gauges with success to do their own alignments at home? I've been eye balling the one with Magnetic Base but am not sure if it would work on our wheel hubs or not either with or without the dust cap removed or if extended wheel studs would pose an issue or not if the gauge does happen to work.
I like the idea of using the ones that do not require the wheel to be on the car but haven't found any advertising an adapter for Ford. They do have ones just for GM though ... : Blahh
I'm not married to either of these brands by any means so if someone does know of a good one that will work on the wheel hub directly I would love to see other options as well.
Thanks for any info you can provide
Here's a shot of the Intercomp gauge:
