S550 Honey Badger GT350 Build Build Thread Profile - S550 Mustangs
758
1,124
TX
If Option #2, would a passenger still be an option at least safely/comfortably? I wouldn't want a tank of 200*+ oil between my legs!!
like the GT4 car, it would be tucked up front and away from your legs. Mine would stick forward a little more than that, but same idea
758
1,124
TX
Okay - chose a location for the dry sump oil tank and went bananas with the cut off wheel tonight. Happy with how it's looking. By opening up the floor into the crumple zone and cutting out the "box" that the HVAC air intake used, I was able to get the can pretty far forward.
Good news is I should be able to access the fill from the engine bay
Currently waiting on some fittings to plan out my hose routing before I finalize the mounting. It's a tight fit juggling 4 different ports.
In the meantime, I mocked up the dash, steering column, and pedals. Dash and wheel conflict, so i've ordered a mount to put the dash on the steering column instead of where the OEM cluster was. This should move it forward and make it easier to see. This perspective is a bit misleading, the top of the wheel covers the shift lights most of the time in this position.
Finally, I've mocked up the pedals. Think I've lucked out on not needing to cut the foot well - which is good. the main chassis rails run directly under the brake pedal.
6,553
8,204
This is my plan as well, I'll be watching.
6,553
8,204
My fittings come in on Friday. that's when the rubber will really meet the road on this position ha
The trick is how well can you heal/toe when the brake and gas are swinging opposite ways….I was going to use a 3 pedal unit and connect the stock gas pedal with rod ends….but if this works I may just go for that instead.
My turn to learn from you. ;)
758
1,124
TX
Ahhh, my mistake. I misread and thought you were talking about the dry sump tank.
the ECU and strain gauge knob will take car or rev matching for me. So not worried about the pedals. I explored a 3 pedal, but was concerned about getting the drive by wire figured out
6,553
8,204
Yeah, that’s why I was looking at connecting with rod ends….are you retaining the ABS?
758
1,124
TX
Okay - made some progress last week on the dry sump enclosure. I need to clean things and take some more pics, but going to wait to do that until I lay some steel it down to and seam seal the enclosure as taking the mounts in and out are pretty tedious. But essentially I built a box with a removal door inside the cabin that will go under the dash. A little heavy since I used 16g steel, but I wanted it to withstand passengers kicking/bracing themselves on it. So I welded to the chassis. Should also add some structural rigidity back into that corner.
On the engine-bay side, I enclosed the hole a bit to add some more rigidity back and protect the canister a little better.
Getting really close to being done with the fab work. Basically just have some final clean up to do on the fuel cell and dry sump tank enclosure. Then I'm ready to weld the cage and paint.
Last week I also completed the final "big ticket" purchases- Speedkore carbon fiber roof, Link ECU and wiring kit, L&M cams, AP Racing brake kit, and a couple other bits. I think I only have the rear diffuser left.
And one of the pieces I'm most excited for came in. Bosch M5 Motorsport ABS Clubsport Kit. This is going to be a real game changer and should really help shrink those brake zones. There's a good 1.5-2 seconds split between Turn 1, 11, 12 and 15 braking zones at COTA from my analysis. Stock unit is great, but not optimized for racing slicks, big aero, and full race pads. FP350S replacement is a really strong option from what I've been told by those much smarter/better than me and what I'd recommend for 95% of those going down the rabbit hole. But all agreed if I could....and against my more rational judgement...I did :D
6,553
8,204
758
1,124
TX
Money bags here....lol.
Ha. Turns out you can save a good amount not running a mustang at a track for 18 months. that and the new job signing bonus. The amount of money I've spent on this build in the last couple months is very sobering. Thankful I can make it happen, but definitely not without sacrifice
6,553
8,204
Save money?
What's THAT?
Don't mind me, I'm just Jelly. ;)
758
1,124
TX
6,553
8,204
1,249
1,243
In the V6L
Actually, you're moving along pretty quickly - Project Binky took something like six years ;)
758
1,124
TX
I applaud your diligence!
My goal is to have the car running by end of year. We’ll see. Really have some events next spring I want to make. The big question mark is wiring. Then programming everything to talk to each other. Ha.
758
1,124
TX
The full AP kit came in while I was on a work trip last week. So pumped about this kit. Total weight savings is about 45lbs of unsprung mass
Stock calipers/pads (add 30lbs for stock rotors) - 44.7lbs
AP kit is 32.2lbs - so 12.5lbs per front corner
Rear stock setup is 27 lbs (when you add 20lbs for stock rotor). I estimate about 3lbs for parking brake stuff based on previous weigh-ins
AP kit is 20.4. So 6.6lbs + 3ish lbs makes it a 10ish lbs difference in rear
And these weights are for the monster 25mm endurance pad/caliper setup. Super pumped
I purchased through Anthony at Drive Faster Now. He'll get you the best price, help make sure the setup is optimized for your car (we ordered some different parts since I am using the Bosch abs) and treat you great. Highly recommend
