How to remove or change side pipe restrictor plates
Tools needed. 15MM wrench and 15MM socket and ratchet(I used a deep well so I wouldnt have to use an extension)
Step one raise vehicle I used a set of car ramps from the front or rear I choose the front this time
Step two remove the two nuts at the flange and the bolt that holds the tip near the rocker panel edge
Step Three remove the side pipe assembly
Step four remove stock restrictor plate (if not installing a different sized plate skip to step six)
Step five install new sized restrictor plate (3/4" plate shown in picture)
Step six re install side pipe by first slipping over studs on flange then threading the rear bolt and loosely tighten bolt and nuts. check clearance you should be able to get you hand around the pipe from front to back adjust as necessary. Once clearance is good tighten all nuts and bolt down and recheck clearance.
Step seven repeat steps one-six for opposite side then lower vehicle and you are done. now wasnt that easy?
Shock Boss said:
Super easy to remove the plates. When I took mine off, I'd say 1/2 cup of water poured out of each side.
I have a set of 3/4" plates I use for db restrictive tracks.
I cut a small line from the hole to the lower edge of the plates to allow moisture to drain.
That sounds like the best of both worlds! NFSBOSS...you might want to consider that for your next evolution of plates.
I installed my 5/8" plates today. I then went for a test drive. There are moments that I think they may be just a bit too loud and other times that I don't hear the exhaust quite enough - so I figure they must be just about right. :)
johnrehder said:
3/4" install was worth the effort. The sound is amazing and I don't think it's too loud while cruising. A nice cheap mod, the perfect kind!
Yep, they're the next best thing to a set of electric cutouts - set them on the fly according to your mood! ;D :mad:
But I bought some plates before the cutouts so did my part to support NFSBoss. :)
