- 6,551
- 8,203
- Exp. Type
- W2W Racing
- Exp. Level
- 20+ Years
Torque arm. In this vid I had the BMR lower relo brackets but this lead me to change to the MM brackets that had more adjustment holes and finer adjustment. This video is a few years old....a lot has changed.Are you still running the stock length early UCA (or upper trailing arm for you and blacksheep1!), or have you changed to the longer 11-14 length? Or perhaps neither and you’re running the Cortex torque arm?
