- Thread starter
- #21
So your "Professional" opinion is F it, DO ITAll OEM. (2) different clutch packs all on the same flywheel.
Pretty much. When I followed the service manual about putting the engine back in the car it didn't mention anything other than using an alignment tool. My personal experience reinforces the approach. But as always, I claim no responsibility if proven wrongSo your "Professional" opinion is F it, DO IT
Yes, send itSo your "Professional" opinion is F it, DO IT
Weird because the ford documentation harp's on needing to align the marks or their could be an imbalance. But sounds like I'm hearing this may not be the case.Yes, send it
I just talked to Leo Capaldi, these engines are internally balanced and the clutch pressure plate has no index marks on them.
I'm aware of that, which is why I took awhile to give you the answer. It's not the first time GM or Ford has done that, as an example the LS Chevy engines want you to mark the balancer when it's removed to do timing chains, but there is no key, no index mark, and the engine is internally balanced, so nobody knows why they do that. The only possible reason I can think of is that the factory balances everything down to the nth degree, but there is still some unbalance so they throw the heavy side opposite the heavy side of the crank, just to make sure.Weird because the ford documentation harp's on needing to align the marks or their could be an imbalance. But sounds like I'm hearing this may not be the case.
Yes no classified info outside the SCIF please.I'm aware of that, which is why I took awhile to give you the answer. It's not the first time GM or Ford has done that, as an example the LS Chevy engines want you to mark the balancer when it's removed to do timing chains, but there is no key, no index mark, and the engine is internally balanced, so nobody knows why they do that. The only possible reason I can think of is that the factory balances everything down to the nth degree, but there is still some unbalance so they throw the heavy side opposite the heavy side of the crank, just to make sure.
Sort of like tires, the fast guys always rotate the tire on the wheel to get the heavy side of the wheel across from the heavy side of the tire to take less weight.
top secret stuff there.. lol
Stang, you could try Ford Racing tech line. Google the number. I have their number, but I'm not near my files. Sorry.Recently secured a new clutch setup for the Gt350. I appear to have hit a snag as the directions indicate I need to align the "paint dots" on the new setup. Unfortunately I can't seem to distinguish any real paints dots on the Flywheel or Pressure plate.
Now the flywheel only goes on one way so thats kinda self explanatory, and there is a white paint dot on the inner bearing of the flywheel. But its on the inner bearing nothing on the outer rim. Clutch plate doesn't make a difference in direction, though there appears to be a green dot on there as well.
Which leaves just the pressure plate. Now I found 2 green spots, one at 11 o'clock and one a7 o'clock (based on current positioning) on the pressure plate, but I'm still not confident those are those paint dots the instructions were indicating. Anyone have any guidance on this? I'm essentially stuck at not being confident on which position the pressure plate needs to go to finish this install up.
Interesting enough I have found NO stock GT350 clutch installs searching facebook and the forums.
View attachment 66852View attachment 66850
Thank you for your picture I was actually able to find the markings. So Super thank you.There are two small weights on the back of the flywheel; the small gap between them aligns with the beginning of the printed part number on the front of the flywheel.
