- Thread starter
- #101
Watching this thread now. First post I’ve seen but you’ve done the same suspension mods I’d like to try. Would love to hear your thoughts on the Vorshlag set up! Mainly the Bilsteins!
Good info. I will make sure to run this by the shop. And yes great tool for the shock towers- I bought one from them and used it to cut. It’s in a couple of the pics above.By the way, @Kona.coyote5.0 you also mention alignment settings....
On the advice of Vorshlag when I bought their StreetPro kit I put the camber plates in the max upright position and then got the toe aligned to zero. That is your street setting. When you go to the track you move the cc plates to max negative camber which also gives a toe-out setting that helps with turn in.
I was laughing when I asked Vorshlag for a good neg camber setting for track days and they responded, "all of it." Gotta love Texas. But in my experience it really is true, you can't get too much front neg camber on these cars at least not with the stock shock towers. They also sell a jig to cut those btw.
I've been very happy with a similar build. I already had the MM camber plates. I went with H&R Race front springs on the Bilstein struts. I opted for Koni Yellow in the rear to be able to dial the damping in a little and the Bilstein Struts seem to be a bigger benefit on the front. I also went with the MM adjustable rear spring perch and some 250 lb/in coilover springs that I can swap out easily if I want.
Just curious if you also did anything to correct geometry. I did go with Rear LCA Relocation brackets, extended ball joints on the front and a bump steer kit. If you didn't, I would be interested to hear how it worked because I also have a V6 that I might go a bit milder (less drop and not as stiff) on.
@Kona.coyote5.0 I have really close to the same setup except for Cortex arms and relocation brackets. With the Vorshlag Streetpros I max out on camber at -2.9. I had contacted Vorshlag about converting the setup to the TrackPro specs they used to sell but they said I was better off just spending the money on coilovers. Too much time and money to do it. I think I do pretty well with the setup. If anything, my driving skills need ever more work. I need to get down to SoloPerformance and get a track alignment. I had an offroad excursion the day after christmas and tore one of my Cortex Track LCAs up. Ended up moving over to the Steet version. You should check out Champaign Country Sports Car Club for events. It has been the main place I autocross. Events in Rantoul.
