Jan
08
Nasa SoCal Season Opener - Buttonwillow
PaddyPrix
728
1,088
San Diego
I'm in, because I wasted money on another transmission and looking forward to another last place TT2 finish.
PaddyPrix
728
1,088
San Diego
Signed up for Saturday...HPDE 1 with an instructor all day.
I'll be there in HPDE 3. Excited to see you guys there!
This sounds fun... I will probably try and get out there. Work on getting my TT license I suppose, need to finish HPDE 4 i think?
Regardless of what you gents think about Toyo, if you haven't already, make sure you ask your instructor/chief for a NASA Passport, something like a race logbook for your HPDE progression. When they promote/sign you off, you get "Toyo bucks", and I believe on HPDE4 -> TT you get a whole set, or damn near with how cheap they are and how much they're giving you. And not being preachy, but they're pretty good tires if you're looking for consistency from 1st to 20th heat cycle, and throughout the session as well.
Edit - now with link!
ChrisM
Mostly harmless.
1,180
1,420
3-5 Years
South Carolina
Will do. I had previously ran with NASA a few years back and was working my way up, but then I took a long hiatus, so just starting over.
106
52
So CA
I've ran NASA a few years back, up to HPDE 3, looking back into it. Been running Speed Ventures events recently. Anybody also doing the Roval on the 15th? I may have time to do both series in 2022 or mix them up. Thoughts?
224
421
3-5 Years
Southern California
I'm certainly not going to turn down a set of free tires. They could give me winter tires and I'd still get seat time out of them. Thanks for the recommendation and looking forward to seeing you out there!
224
421
3-5 Years
Southern California
Looks like I'm probably out. While getting new tires and an alignment, it looks like three of my wheels are bent after my trip to Buttonwillow earlier this month. That Apex group buy can't come soon enough it seems.
106
52
So CA
Bent wheels are the stockers? Ouch didn’t know they’re that soft. Are most of you running square setups for track?
224
421
3-5 Years
Southern California
This will be my first event with NASA. Does anyone know how long it takes to pass tech for HPDE? I plan to get to tech as early as possible since my driver's meeting is 30 minutes after tech opens. I've already reviewed the sheet and everything should be taken care of.
1,184
2,185
Are you going both days? Saturday tech is typically busier than Sunday with the ST/TT groups. This being the first event of the year, probably more so as many will be getting their annual inspection completed. If you’re driving Saturday, get in line early as possible.
