rear rotor question
ArizonaBOSS
Because racecar.
8,730
2,734
Arizona, USA
LONG shot on this one but one time I ordered a set of Centric front rotors that had been miscast; one of the discs had solid metal in about a quarter of the vent slots inside the disc. I didn't use it because I knew it would cause an imbalance.
You might take your wheels off and see if you can shine a light through the vertical portion of the disc to see if everything looks normal or if there is some sort of blockage causing an imbalance.
675
253
Silver LS - that is weird because I ran 19x10 Ford Racing Boss 302S wheels at all four corners with zero issues.
ArizonaBOSS
Because racecar.
8,730
2,734
Arizona, USA
Re: Boss 302s wheel
Silver LS said:
Bought a Boss 302s wheel to use on as a spare on my 2012 LS and it would not fit the hub. Any one know why?
Should fit right on. Is the hub rusted? If so, clean it.
Re: Boss 302s wheeel
This thing is way off. It is 18x8.5 That seems small for a race wheel. I am beginning to think it was miss advertised the seller on ebay was really flaky.
I got a 18x9 SVE drift wheel and it works great. Tighter than stock but fits.
Re:Boss 302S wheel
It is a BBS wheel Part Number R6406. I can not find any information on what it fits. There is one left on ebay Don't anyone buy it. It is advertised to fit. Kristin is the seller.
