Ok here we go..Drag race application striving for 0 camber at rest and thru some bump and extension, lowered S197 w/ ford 5300RA springs, FCA's are now virtually horizontal , (1.5* downhill from k mem to BJ ) originally when lowered had way to much neg camber, CC plates extended the tire too far out of the wheel well, and refuse to use those skinny camber bolts at the strut/ spindle. Sooo, after removing CC plates, I measured how much was needed to shorten the LCA's to get a 0 camber or very close to it, bought a set of used low mileage arms and shortened them 13/16" . while I was at it, installed New Prothane bushing kits and put it together, shortened the tie rods and ends (stock) proportionally. Now I have 0 * / .25* at ride height, so my ruler didn't lie .... but now I'm at a camber change rate i don't like and bumpsteer is not good. My question is anyone out there with an analysis program or familiar with the S197 suspension plotting to get this Camber Curve in the Ball park? I'm considering and have extended Ball Joints, X-11's at + 1/2" or Forgetrues at +7/8" .. and have a bumpsteer kit ready to go,. Any final Camber fine tuning will be accomplished by Using the Ford S197 full size camber bolt correction Kit # M-3B236A ... TIA Steve
