Street Brake Pads
KNS Brakes
Supporting Vendor
292
20
Cary NC
We have a variety of Street Brake pads in stock. Below is a full list of our current selection.
Hawk HPS 5.0 Brake Pads
Hawk High Performance Street 5.0 Brake Pads offer improved braking performance with excellent street driving characteristics.
Ferro-Carbon semi-metallic compound improves stopping power and resistance to brake judder.
Moderate dust levels with no noise and low rotor wear.
Best suited for street driving where improved feel and harder use is needed.
Hawk HPS Brake Pads
Hawk High Performance Street Brake Pads improve braking performance over most OEM pads.
Semi-metallic compound improves stopping power and resistance to brake judder.
Moderate Dust levels with no noise and low rotor wear.
Hawk Performance Ceramic Brake Pads
Hawk Performance Ceramic brake pads are engineered to create a quiet and clean performance brake pad.
Ceramic compound makes very low amounts of brake dust.
Pads are quiet and have very low rotor wear.
Best suited for street driving where minimal noise and dust are desired.
Hawk HP Plus Brake Pads
Hawk HP Plus brake pads are high friction street pads.
Semi metallic compound has very good bite at low temperatures and have a higher temperature range than most street pads.
Expect more noise and dust then typical street pads. Some increased rotor wear is expected.
Best suited for aggressive street and autocross type driving. Entry level track use is possible in lower load applications.
G-LOC GS-1 Brake Pads
The G-LOC GS-1 is a high performance street compound. GS-1 provides very little dust and very little noise, while maintaining excellent initial bite and torque for street use.
Not all G-LOC products are stocked. In the case that they are made to order (MTO), production time is typically 5-7 business days. Please inquire for details.
G-LOC R6 Brake Pads
The R6 has been specifically engineered for Autocross applications. An ultra high cold torque compound delivering consistent performance from dead cold (0°F) up to 1000°F + (0°C to 537°C+).
Ferodo DS2500 Brake Pads
Ferodo DS2500 compound is primarily designed for high performance road use.
Wide temperature range and moderate friction level.
Will work cold and does not wear rotors excessively.
This pad can be used for street and light track use but may make some brake noise.
Carbotech 1521 Brake Pads
High performance street compound known for its excellent initial bite, release and modulation. Low dust, low noise, and very rotor friendly.
Carbotech AX6 Brake Pads
The AX6 is specifically engineered for Autocross applications. This compound delivers reliable and consistent performance over a very wide operating temperature range.
Temperature range 50 - 1100° F (10 - 593° C)
High Torque - Good Initial Bite
Girodisc Magic Brake Pads
Girodisc Magic brake pads are a great solution for dusty, loud OEM brake pads.
Magic pads have good initial bite and strong brake torque.
Semi-metallic compound produces moderate dust, no noise and low rotor wear.
Excellent balance of performance versus dust, noise and wear.
Girodisc S/S Brake Pads
Girodisc Street/Strip brake pads are aggressive high performance street brake pads with very high initial bite and high brake torque.
Works up to 1000 degrees and resists brake vibration and judder.
Excellent all-purpose pad for cars that need strong braking. Autocross, heavy towing or mountain use etc.
Will produce more than normal amounts of brake dust and may squeal under certain conditions.
StopTech Street Brake Pads
StopTech Street Brake Pads offer improved braking performance with excellent street driving characteristics.
Low Dust - No Noise - Low Rotor Wear
Primarily suited for regular street driving
StopTech Sport Brake Pads
StopTech Sport Brake Pads are aggressive street pads.
High initial bite and high brake torque.
Typically quiet but will produce more brake dust than most street pads.
Best suited for hard street use, autocross, and other demanding applications.
Centric PosiQuiet Ceramic Brake Pads
Centric Posi Quiet Ceramic brake pads offer friction levels similar to OEM formulas with low dust and no brake squeal.
Centric Posi Quiet brake pads are premium quality brake pads designed for street driving under all weather conditions.
Available for most Japanese and Domestic models.
Not all products are available for all models. Please use the car selector on our website to check stock. Thank you for your business.
