My '18 RS2 had a Roush supercharger installed on it when it was sold new. The dealership ordered it at the time of purchase and was put on about 500 miles later. I bought the car last year with 4800 miles on it and currently am at a little over 18k miles. I've already had to replace a catalytic converter, and the other one has tripped the check engine light once already, but is currently not on. When they replaced the one catalytic converter (less than 1k miles ago), I had them upgrade form the 700hp tune to the 750hp tune. My understanding is that the 700hp tune is notorious for taking out catalytic converters, but the 750hp tune seems to be fine. One thing I've noticed with both tunes is that I sometimes hear a pinging/detonation sound under medium to heavy acceleration. I was "informed" by someone on another page that the knock sensors "won't let it do that", and I must be hearing something else. As far as gas, we only have 91 octane available locally, so that's what it typically gets. The 750hp tune is optimized for 93, but says 91 is acceptable. I do have a barrel of Sunoco 260GT that is 100 octane that I spike the gas with if I'm headed out for an autocross or otherwise know I'll be running the car hard. I don't know if straight 100 will clear it up, as I haven't had the car back with the new tune and been able to run straight 100. With straight 91 it's definitely making a few noises I don't like. Is there something "normal" that would sound like a bit of detonation? It mainly seems to be while I'm aggressively tipping into the throttle (I can't just mash it, as that would typically result in instant wheelspin in anything less than 4th gear). The car hasn't thrown any codes other than when it did the P0430 and P0420 for the cats. I've got Forscan, but haven't figured out how to find if there's a record of detecting knock somewhere in the memory. I'd like to get this figured out, as I know what detonation can do. It may just be that our local 91 gas is all junk, but I'd like to know if there are any other possibilities that it might be. It'll be next spring most likely until I can get the gas all drained and run straight 100 octane. I really hope that the $9/gallon solution isn't going to be mandatory for running the car hard. Oh, the joys of 12.5:1 C/R and a supercharger! Thanks for any insight you might have.
