Suspension groans after k member swap - suspect a arms?
Fabman
Dances with Racecars
6,518
8,154
Fabman
6,518
8,154
I'm seeing a few bolts, so I'm confused. Is it where the z-brace bolts to the K-member in the front? I'm uneducated on what a rack bolt is apparently.
Yes, if you follow that bolt up you’ll see it also mounts the rack. I inverted mine so the nut is on the top. That’s where my jack goes.
Sent from my iPad using Tapatalk
Fabman
6,518
8,154
51fdd3705b191ce53d4e6fb5324167e0.jpg here:
Fabman
6,518
8,154
I was thinking maybe you meant steering rack but I thought jacking on the steering box area in general might be.... frowned upon?
Someone is always frowning on something....meanwhile I have been doing this for about 5 or 6 years with no issue. As soon as there is a problem I’ll be back to report.
