SN95 T56 Harness Wiring
1,179
2,176
Has anyone installed the wiring harness from LMR https://lmr.com/item/LRS-85656/t56-transmission-sensor-connector-pigtail-kit on a T56 swap? I can't seem to find any instructions and I don't want to hack up the existing harness any more than needed. BTW, this is in a '97 Cobra and the existing harness is for the stock T45. TIA.
I used the Bowler all-in-one harness - Modern Driveline specs this with their kits. These 2 docs from Bowler should have all the info you need. If you don’t have the Bowler harness, I strongly recommend it. The Bluetooth interface makes it extremely simple to make small tweaks to the VSS output signal so you can dial your speedo in. Otherwise, I don’t know how you’ll convert the T56 square wave signal to the digital input the ECM is looking for.
Couple other notes - I chose to use the factory 12v ECM wire in the factory harness. The instructions recommend a clean 12v source, but I’ve had no issues with using the harness. Also, you’ll have to have your tuner add the T56 gear ratios to the tune otherwise cruise control won’t function properly.
Here’s the link for the instruction on MDL’s site if the pics are tough to read:
https://www.moderndriveline.com/sho...magnum-all-in-one-harness-w-reverse-lock-out/
1,179
2,176
Sorry, just realized this is for your ‘97 and not your ‘11. Hopefully the first pic will still be helpful to map out what signal the sensors are looking for.
63
50
Raytown, MO
Well, the car is not street legal anymore so the cruise control is gone. I'm mainly interested in the reverse lockout and maybe the speedo but I don't look at it during an autocross run anyway. FWIW, I can peg it before getting out of first gear with how it is hooked up now.
63
50
Raytown, MO
Update, I ended up removing the spring in the reverse lockout so now I don't have to lean into it to get reverse. The thing hardly ever gets into 3rd so there is little chance of accidentally getting reverse when I want fifth.
