S197 Team Old Goats Build Thread Profile - S197 Mustangs
Ok. One side done. I will make sure I have all 8 electrodes in my hands. These look like the ground strap breaks from pushing the porcelain down OR a piece of the ground strap ( small piece ) broke off from each. One was missing a piece of porcelain. I will go borrow a borescope to see what’s laying on piston tops. If I have each electrode do I really need to worry though?
Extract what is left of the plug first, did you see my link?
Yes , thanks. I have extracted 4. Blown out the holes. I think one small piece of porcelain is in one cylinder and maybe a little material from the ground strap. Other than that I have plugs out as expected. Just not sure how critical it is to get every bit out from piston tops. I’ve seen posts that say it will blow out. I’m not sure I like hoping for that to do the trick. About to tackle the other four :(
8,289
Run a magnet down there on the end of a stick of some sort to try and get the metal chunks out. As for the porcelain and bits of crud, we'll it's like the kid that swallowed the toy soldier..
That too shall pass
Please stand buy as I wait for another extraction tool. The threads on the pusher body failed on plug 5. I ordered a second tool. One for me and one to replace the broken one I borrowed. Why did I think I could slap a car together in a reasonable amount of time :(
6,400
8,289
The NAPA version uses a threaded puller, I think it's more reliable than the Lisle which is self tapping. That also, is covered in my link and might give you some options. My Lisle only lasted 4 plugs, so you're ahead of my game. Just make sure you replace those plugs with 1 piece units.
6,400
8,289
YOu ARE HERE
Ok so here we go..
A couple of caveats, if the top of the electrode stays with the porcelin in the plug bore, break it off. Or try to extract it
( good luck with that one) the electrode has corroded to the porcelin and it wont pop out and go into the combustion chamber. If it does, you can still fish it out with a small magnet. The reason is that you need EVERY bit of metal there for the tool to grab.
As it was, the Lisle tool worked spectacularly until plug 4. It was tired on plug 3, but plug 4 was a no go and it pulled out of the metal.. so..
Because I'm a realist, I purchased both a Lisle and a NAPA version. The lisle is by far the better piece IMO.
The difference is that the NAPA version actually uses a tap to make the threads, and the puller threads on those. In real life, this puller pulled out as well, but upon further review I noticed the tap was a standard tap, it should be a bottom tap, so a trip to the grinder created a bottom tap. I ran it in, it grabbed and #4 was exctracted.. done deal.
These things make all sorts of snaps and pops and its pretty unnerving, but it's just the way the tool works.
Now " Onward! into the fog."
Plugs changed. That was a chore.
so seat base that bolts to floor is 14 inch and seat is 16.5. I also want to slide seat more towards center of car. So out comes the plasma cutter ! I will make a flat plate to bolt to sliders and then bolt the seat to that plate. The seat bolster is touching the ebrake handle so I will have to massage that.
Not sure I want the roll bar mirror or if I will use factory mirror. It’s installed as I want to make sure that a helmet hanger and steering wheel hanger don’t interfere. I’m tired of my helmet rolling on floor. And I plan a cool shirt box in the passenger seat.
My big wang(S) arrived. One is for the s197. Got all 3 wicker bill sizes so if I need to tune things I have options. Fake wing comes off this weekend so my car cover fits. Friend will be making me a custom car cover soon. Phase 3 is weight reduction and the windows will come out when I get to that. Phase 2 is aero and paint. Getting closer.
Lost a seat bolt. After 20 minutes of searching and fishing with a magnet I give up. Off to the nut and bolt store tomorrow, need some hardware for the dash anyways.
seat is in, window net is done. First time I used a spring loaded window net, I sure like it. Might convert one of my other cars to it, I have sliced my head on the buckle clip in that car a few times.
All fun and games unless something vibrates loose. Onto the lower dash. ( kill switch, switch panel, tablet tied into race capture pro ). Oil press/temp, water temp/volt, fuel pressure, wideband. And a nice flat spot for sponsor logo at the glove box location, that will show on video like I am a pro team or something, haha.
My Kenny Brown parts finally showed! 4 months. Waiting for rear wheel studs, fire system, that’s it!
Made a little progress on aero, on dash, on kill switch wiring. My tig machine blew up and I just got it back. Tonight is welding aluminum for fender/hood vents. This weekend is bolting on the KB stuff. Next week is more wiring ( guages ).
The bumper from duraflex really sucks, going to be a lot of body work to fit it, need to make new mounting flanges from fiberglass and cut the old ones off.
