Third oil change and Fumoto install with very little mess. Lots of pics.
I finally hit 10k miles after picking up # 733 in mid June. I'm trying to stick to every 5k on the oil unless I track it hard in the summer and feel like it needs it. This time I used my Form-A-Funnel which worked wonders keeping everything clean.
Also installed the Fumoto valve BEFORE draining the oil! ;D
There was some oil and dirt in there, but it's been 5k miles since I had it unbuttoned. I cleaned that up before I started.
[size=10pt]
A cool anti-drainback feature on the filter. See how it won't settle any lower.
[/size]
Hook up vacuum to the crank case, remove oil pan plug, install Fumoto. ;)
Not much room for the nipple, but it's not needed as you can see.
This is the only mess and it's 4 inches wide as it runs out of the kitty litter scoop.
And now out to replace the trans fluid. Using the stock stuff since my trans works incredibly well.
darreng505 said:
That's a good idea. I've been keeping the 'nipple' off until I need to change the oil, but that looks like a cleaner solution.
I got clear plastic tubing from Lowes that slips easily onto the valve and I run it right into the oil bucket.
yup, I'm going to go that route as well for the future oil changes. going to get a 3/8" tube and run it to empty oil bottles/containers... that will save me a few messy steps of transferring oil from the drain pan to the bottles.
jneary
Performance Fords
323
0
Norcal
So, since I put my oil filters in zip lock bags for the recycling, I simply placed it over the oil filter as I unscrewed it and kept the open end of the bag above where the oil cooler is... Much easier to contain the Exxon Valdez that is a boss 302 oil filter change than before. I had no mess this time as I did the first change. Also, it is important to get the front of the car high enough for the plastic shield to drop down vertically.
