S197 3V TR-3650 rebuilders?
As y'all may recall, I'm building an '06 GT into an endurance road racer. It seems that the transmission, which has 140,000+ miles on it, has a throw-out bearing that needs replacing. I've called all the local transmission shops and none of them want to rebuild it, either because they don't want to touch a transmission that's going to be used for racing—even though we're keeping the engine mostly stock—or because they have trouble getting parts for them. Most have suggested getting a remanufactured unit.
Any recommendations on remanufacturers? I'm seeing prices from $800 to $3,800, but not a lot of details on what the different companies are doing.
We're not planning on any engine mods, other than some intake / exhaust work, and maybe cams, so I don't need a transmission that's going to handle 1,000 (or even 500) horsepower. Thanks!
82
145
Los Angeles
I've rebuilt mine myself a few times. 5th gear change to 0.81 is worth it. I'm waiting on a close ratio gear set from G-Force for the next evolution. Use actual tremec parts from Hanlon Motorsports or off of ebay once you find the part numbers. Only problem I had was when I used Synchrotech blocker rings, they fell apart, so stay away from those. I also put in a billet 3-4 shifter fork, I bent the stock one after 4 seasons of racing it.
1,184
2,185
@Don Lariviere mentioned Hanlon above for parts - they also sell different stages of rebuilt transmissions - link below. @Andrew Weidemann has been using a Hanlon in his Shelby GT - I’m sure he can provide some feedback.
https://www.hanlonmotorsports.com/product/05-10-tr-3650-5-speed-transmission/
6,400
8,289
T45, but you will run into some of the same challenges, you can rebuild them yourself, just be patient and work through it, there is a lot of tips in this post.
Take a look at Lashbrook. I like their pricing and turnaround times.
They offer a mid-priced option, but again not a lot of details on what separates it from a $1,300 rebuild. They do offer parts, though! If I end up dealing with a company that doesn't require a core, then Lashbrook could be a good source for parts to rebuild the original as a spare.
Thanks!
Thanks! The Lucky Dog rules would allow us to swap in the T45, but if we ever want to run in any of the NASA or SCCA classes I think we'd be out of luck, so at this point I'm going to try to stick with the 3650.
In fact, now I'm just leaning towards a new clutch and throw-out bearing and calling it good until it pops.
82
145
Los Angeles
I put this flywheel in my 2008 American Iron car with a Spec stage 4 unsprung disk. That alone made a huge improvement is shifting of the 3650.
If you run a sprung hub it may not work with this flywheel - measure everything!
