Dave_W
You can use the links to the suspension calculators from here: https://cortexracing.com/support/wheel-frequeny-calculator/
Note the different links for rear heave and bump, and the Suspension Leverage ratios are different for each. In heave (two-wheel bump) both springs work are compressed the same, independent of location. In single-wheel bump, you can picture the axle pivoting on the non-bump wheel - for a coilover, the bump-side spring applies all (or most) of its force and the non-bump side spring applies none; for stock perches, both springs contribute to the bump-side wheel rate but in different amounts per the leverage they have based on their locations.
All that said, I agree that most times proper damping has way more influence on ride quality.
