- 137
- 147
You may want to go to a watts linkage instead of that panard bar...JS
Ill look into watts link, thanks.
[/QUOTE]My opinion is better potential for grip on corner exit with the shorter arm…all depending on the rest of the rear setup in both geometry and hardware used. It’s all in the dynamic changes of instant centers for each side.
Perhaps Ford was prioritizing straight line acceleration more with the extra power given to the later S197s . . .The longer arm should have less migration of such points and could potentially be more consistent. I think this is generally true of the OEM setups and why Ford made the update.
I hope that’s not too vague.
Could you send me this file, it does not open for some reason.The simplest, most trouble free way to build your suspension system
Except the watts, you can skip that part
True, but that could introduce other complications (i.e., wheel centering) and is additional expense.If you don't want to adjust pinion angle with the upper control arm you can always do adjustable lower trailing arms.
If shimming the trans mount is not a viable option, I'd rather go with an adjustable UCA
Or you could do a toque arm and never have to worry about pinion angle or anti squat ever again.Everytime you start switching out suspension parts there are trade offs. The UCA is probably the most common way to correct pinion angle after altering ride height. The UCA is a bit of a pain to install and adjust with the suspension at ride height. Adjustable lower arms do have to be adjusted evenly to keep everything in alignment, but they are easier to get at. It isn't an option I would choose for the reasons you stated. I was just pointing out another option.
