S550 Wrecked 2.0+ Build Thread Profile - S550 Mustangs
73
122
Corona, Ca
Here is the 2020 GT350R I plan to restore. Passenger front frame rail needs to be replaced as well as the front body and chassis parts.
Both of these cars are for recreation track use. We are not trying to make them trailer queens or show cars. They will be abused on our local tracks.
This car had nasty crash at Summit Point Raceway.
Bill Pemberton
8,496
8,493
Blair, Nebraska
Nasty crash, Gman you are definitely a master at understatement , ha! Ouch, ouch, and ouch again, but we all look forward to the nose job you will perform and the rebuilding of Humpty Dumpty!
Bill Pemberton
8,496
8,493
Blair, Nebraska
Damn those are brand new Michelins ---- the Gold Standard for sticky slicks! But you only have 7 of them , which car gets shortchanged, ha?!
122
Corona, Ca
We tried most of the tires available and found these to be our favorite.
These are some of our old cars we have and the modern muscle is such a joy to drive on the track. Once they drove my first GT350 they had to have one as well. So here I am building them cars.
756
1,115
TX
You sir, have excellent taste!
Bill Pemberton
8,496
8,493
Blair, Nebraska
Well, she does look good and just seeing a picture of a Mustang at a track is hard on us folks in the Midwest ----- one more month and things will look up for the folks in frigid land! Sounds like the shakedown only found a few items, so the rebuild has to be consider a solid success!
73
122
Corona, Ca
On my 17 we would run 7-8 sessions and never have the motor get so hot. When we came in after a session on the 18 the coolant would percolate and start spitting out the expansion tank. We would have to start it up and let it cool down for 3-5 minutes. We will be adding some ducting and remove the AC evaporator core to test on the next track day. The gauge shows normal operating temp. Any help would be most appreciated.
73
122
Corona, Ca
Did you pull vacuum on the system?? A small pocket of air can cause havoc.
We sealed it up for the day and replaced the part when we got home. The nipple was broken off. I keep reading about vacuum block of plates and was wondering about them. It is a should do type of thing?
TMSBOSS
7,551
5,283
Illinois
Its a sometimes it bites you in the A*S kind of thing. I have refilled several times with a coyote and voodoo and been fine. One time.....not so good. I always pull vacuum on the system now. I bought a air over vacuum pump and just suck the fluid into the system now. Overall, I think it takes less time to just pull the vacuum and draw the fluid in and be done with it over waiting for the engine to get hot, blip the throttle to "Get the bubbles out" and mess with a hot system. YMMV. Same with the clutch hydraulics. Pull a vacuum and be done with it.
Hope this is helpful.
73
122
Corona, Ca
Usually take me less than two hours to drop the front cradle but the frame rails had to be pulled straighter so I could get the motor out. I picked up another motor with a bunch of goodies already installed. Long tube headers, rear oil and coolant lines, MMR timing guides, GT500 coil packs and oil pan. It has under 500 miles track miles on it (he just built himself a monster motor!)
carver
breaker of wrenches
446
605
ontario
Ya know s*it gettin real when there is a sawzall in the picture !! Hah. :hellyeah:
73
122
Corona, Ca
Assembling the Steeda K-Member with new motor. Some damage to the original motor I would not have caught had I not torn the engine out. The impact broke 3 of the 4 bolts off the oil filter housing and it looked OK until I disconnected the oil lines. Now I need to check to make sure the surface is flat and not bent up. The impact was so hard it broke the stud off the top of the motor mount as well.
The intake is not what I'll be using I put it on to make sure nothing dropped in the holes!
