Welcome to the Ford Mustang forum built for owners of the Mustang GT350, BOSS 302, GT500, and all other S550, S197, SN95, Fox Body and older Mustangs set up for open track days, road racing, and/or autocross. Join our forum, interact with others, share your build, and help us strengthen this community!
Appreciate you guys, more than you know, and we got power back on about 30 minutes ago. My wife was screaming words of joy, " We can make coffee, honey I think we will survive !!"
Seeing the extreme damage with 250-300 homes damaged or destroyed... (see full post)
Had an exedy hyper single clutch, new slave cylinder, pilot bearing and ford performance one piece driveshaft installed by a local shop.
Hopefully that will fix the high rpm lock out.Joking apart really pleased I was able to take my car to... (see full post)
You don't need a press to install those bearings, flip the old bearings over. Place them on top of the new bearings so you don't damage the new ones, and tap them on with a hammer. (see full post)
Lot of good stuff there. Thanks.
I watched enough videos to know I didn’t want to get into overhauling the diff. I was not aware that just swapping the carrier with no gear changes is a possibility. It sounds about the same level of... (see full post)
Dracon Speed Cup R2 - Dracon - 27.04.2024So after the Money Shift scare at Serres which luckily was short lived and required only an oil change and compression testing to be solved. It was time to go to Dracon for the 2nd round of the Dracon... (see full post)
Pressure Mapping quiz part 2
So far, your pressure map looks like this''
7AM @70A/70T start psi is 20 front/ 19 rears with a hot target of 30f/29rfirst practice looks like this.
80/90 LF 32, RF30, LR29, RR27 "gain" is LF12, RF10, LR10, RR8...
