Bang for buck camber adjustment
40
32
Nova Scotia Canada
looking to get -2 to -3 degrees of camber in the front
car has stock springs with koni adjustable shocks, wheels are a 18x9.5 ET 45 with a 20mm spacer hoping to run a 275 or 285 tire
wondering which camber plates and or camber bolts are worth buying and which ones are generally considered junk
40
32
Nova Scotia Canada
You can't go wrong with the Vorshlag plates. Maybe not "bang for the buck" but highly regarded around here, definitely not "junk".
To get close to 3° you may need to open the hole at the top of the strut tower too.
I don't trust camber bolts so much.
id seen lots of people talking about them. unfortunately they are quite a bit out of my budget
JDee
Ancient Racer
1,809
2,012
5 miles from Mosport
I had Vorshlags on my '16, with cutting the strut towers was able to get -4. But that was a heavily modded car that was pretty much track only. With the Mach 1 I put on BMR and with no massaging I got -2.2 which I think is fine for a dual purpose car that will see more street than track time.
xr7
TMO Addict?
721
844
Minnesota
If you are considering camber bolts I have a pair of never used camber bolts that I can donate.
93
67
Cantley
It's funny I did it the other way around from you: I had BMR on my 2019, and I bought Vorshlag for my 2024. I have yet to install them. For having tried both, do you reckon I should get more camber with the Vorshlag, without cutting the strut tower, or is 2.2 pretty much the max you can get irrespective of brand?
JDee
Ancient Racer
1,809
2,012
I think you can get more than 2.2 with the Vorshlag without cutting. I think I got a little over 3 when I first put them in. Just had to go for more though. It was a very worthwhile thing, that car was on rails.
Think about biting the bullet and doing the camber plates once with the Vorshlags. It stings the pocket book in the beginning but could save you in the long run buy not having to purchase and maybe pay for labor on a second set when you realize you want/need more camber. The second set will probably end up being Vorshlags... I'm at 3 without cutting the towers on an S197. If you can't afford now you could take the offer on the camber bolts and have a good alignment shop max you out and have fun. It might be harder on the tires but gives you time to save.
40
32
Nova Scotia Canada
View attachment 94665 Nothing says , Bang for your buck , like simply drilling the towers and getting -3 degrees that will never go out of adjustment. It's old school but it works!
I had actually considered doing this! My only concern was not being able to adjust it later if I decided to change the setup but I guess I could just buy camber plates at that point
40
32
Nova Scotia Canada
Buy once cry once. That is a good way to look at it as well. Does Vorshlag still make the camber plates for the s197 new or would I have to find them used
317
267
xr7
TMO Addict?
721
844
Minnesota
I appreciate it but my guess is shipping them to me would be more expensive then me just buying them with me being in Canada and all
Meet me in Thunder Bay, I'll leave them under a bench for you at Tim Hortons!
Sorry, I should have looked where you were located. I think this box of camber bolts have been sitting around here for 6-8 years.
Yikes! I'm glad I got mine in 2021. They went up just like everything else. You definitely do get what you pay for though.
100
147
Olsburg, KS
Add me to the Vorschlag list. I've got them installed on my '18 and just need to get them installed on my '08. I notched the towers on my '18, but don't get anywhere close to them at the 2.7 degrees I'm set at. When I initially took it in to get aligned I was well over 3 degrees without getting into the notch. The price has definitely gone up the last couple of years. I'm glad I got them when I did.
