Can someone please tell me what the 4 connections are to the positive terminal on the battery?
There is the main bracket, one on top of it, then 2 others connected to the 100 and 200 amp sides of the circuit breaker . what do each connect to ? I don't have a manual.
I accidentally cooked the 100 amp side while changing plugs. I started the car fine with it popped, the starter operated normally , car ran fine, but no power steering and had message that said to check advance track.
Replaced circuit breaker. Start car and the starter will not disengage . it won't start I think due to the starter not disengaging. Jist bump the key over and starter keeps on spinning on its own unless you turn key to off.
I suspect the solenoid is cooked. Just want to make sure before I go out and buy a new starter. I tried disconnecting both sides of battery for 5 min. No change.
Its odd that old cooked circuit breaker will start the car fine. Either solenoid is cooked or it isn't I would have thought. Wtf?
Sent from my LG-H932 using Tapatalk
