GT350 Carbon Ceramic Brakes - now available for all four corners!
1,249
1,243
In the V6L
Finally installed TBR CCBs, and a 1st event for break-in. Only put CCBs on front. Finally got a good transfer layer after 2 sessions at Harris Hill, so really only got one session at speed, and seems to be at least comparable to the iron brakes. Front end seems a bit nimbler with weight reduction. As the track was a bit worse for wear than my previous HHR outing in 2020, I couldn't break my PB on track, but was less than a second away. I also installed Vorshlag deflectors for the inside of the rotor, along with titanium pad shims to help heat stay isolated in the rotor and pad. I am thinking the dividends will really show at COTA. I'll post a follow-up after next event.
Hey, thanks for posting! It's good to see someone else talking about ceramic brakes. Which pads were you running? RSC1's are on the TBR website - is that what you've got?
