2017 Mustang GT Profile
HPDE/Track
2017 Mustang
GT HPDE/Track -  (2017 Mustang GT Track Build)
Specs & Mods
Ownership Status
Currently Own
Year
2017
S550 Model
GT
Transmission
Manual
Mods - Handling
Ford Performance Track Suspension
BMR SP083R Handling Springs
Steeda Camber Plates
Steeda Front Sway Bar
Steeda End-Links
Steeda Roll-Center Correction Lateral Links
Steeda Front Control Arm Bearings
Steeda Bump Steer Correction
Steeda 2-point Front Subframe Brace
Steeda Rear Shock Mounts
Steeda IRS Braces
Steeda Poly Vertical Links
Steeda Rear Camber Adjustment Kit
Ford Performance Knuckle Bearings
BMR Rear Lower Control Arm Bearings
BMR BK048 Aluminum Cradle Bushing Kit
BMR BK051 Poly Differential Bushing Lockout Kit
Cobalt XR1 front / Raybestos ST-45 rear pads
Girodisc Rotors
Vorshlag Cooling Deflectors
Castrol SRF Fluid
SVE R357 19X11 ET50 with 315/30R19 Continental ECF squared
Front OP Mustang 25mm spacers with ARP extended studs
Mods - Power
ARH Full Exhaust
L&M Intake Cams
GT350R Valve Lash Adjusters
GT350R Cam Phasers
Manley H-Beam Rods
Wiseco 11:1 Pistons
ARP Main and Head Studs
2018 Intake Manifold
GT350 Air Intake
Max Bore 84.5mm Throttle Body
Setrab Oil Cooler
Moroso Oil Pan
GT500 Valve Covers
BMR Motor Mounts
Bob's Oil Catch Can
Exedy Hyper Single Clutch
Dana Spicer One-piece Drive Shaft
Blowfish Racing Shifter Bracket
Mods - Exterior
Wire Mesh Grille
Trackspec Hood Vents
Mods - Interior
Watson Bolt In Roll Bar
Sparco Circuit Seat
Schroth Harness
Rear Seat Delete
Background & Plans
Driver mod required.
TMO Supporting Vendors
Car information
Added by
thelostotter
Views
6,159
Last update
Share this Car
