2005 Mustang GT_46L Profile
2005 Mustang
GT_46L  (Fiona - Road Course, AutoX, and Optima Build)
Specs & Mods
Ownership Status
Currently Own
Year
2005
S197 Model
GT 4.6L
Transmission
Manual
Mods - Handling
H&R Sport Performance coilovers and dampers
Eibach sway bars - front adjustable
MM caster/camber plates
MM bumpsteer kit
MM adjustable rear control arms
BMR adjustable rear upper control arm
JLT rear diff catch can
F - Brembo 14" 4P, KNS by DBA rotors, Carbotech XP-20 race pads, and Boss 302 brake ducts
R - Stock calipers, KNS by DBA rotors, and Carbotech XP-12 race pads
Apex Racing SM-10 wheels or HRE FF15 wheels - both in 19x10 ET40
Steeda radiator support
Mods - Power
FRPP 3.720 bore iron alloy block (BOSS50) 519whp - 501 ft lb on low boost
Livernois 3V stroker crank by Kellogg (3.75" stroke)
Livernois H beam stroker rods (by Manley)
Diamond 3.720 stroker pistons w/ 22cc dish (9.5:1 compression) w/ Total Seal stainless steel rings
JDM Engineering cams w/ custom grind
FoMoSport Stage 3 heads w/ over sized valves (50cc combustion chamber) w/ FRPP etched valve covers
Cometic head gaskets
Phase locks
ARP head studs
Kenne Belle Stage 2 - 2.6L supercharger
8-rib overdrive serpentine belt system with DOB Frankentensioner
FRPP dual 62mm throttle body
JBA long tube headers 1 5/8" primaries w/ 3" collectors, gutted JBA shorty H-pipe, Roush Extreme Performance pipes, MBRP SS mufflers
Fore Innovations dual pump (TI 90000274 primary and TI 90000285 secondary) w/ 8AN lines
Advanced Fuel Dynamics Pro Commander adaptive flex fuel system
BBK high flow aluminum fuel rail kit w/ ID1000 injectors flowing E85 or 93 octane pump gas
Meziere electric water pump
Mishomoto high capacity performance radiator
Mishomoto oil cooler kit w/ thermostatic sandwich plate
Livernois billet oil pump gear-rotor in FRPP hi pressure oil pump
2013 GT500 8-quart cast aluminum oil pan
Pro-Dyno tune by Dan Desio
Mods - Exterior
Black paint above the style line and rear decklid - Silver painted pinstriping
Kaenen 3" cowl hood
Foglight delete and black billet grill
Roush fuel door
Roush side skirts
Mods - Interior
Ford Racing by AutoMeter gauges (water temp, oil temp, fuel pressure)
MM 6-point roll bar w/ removable harness bar and door bars
Schroth 6-point harnesses
OMP HTE-R XL seats - driver and passenger
Rear seat delete
Pump and fan switch panel
Background & Plans
I purchased Fiona from a West Point automotive engineer that had done several mods to the car. Some done well, some not so much. If something breaks, I improve it.
TMO Supporting Vendors
Car information
Added by
Boone
Views
4,531
Last update
More in S197 Mustangs
Share this Car
