S650 2024 Ecoboost Build Thread Profile - S650 Mustangs
343
348
So Cal
I am working on a brake upgrade. Mainly because there are no good pads available for the current brake system. The front is pretty easy to swap out to the PP Brembo's The rear will require replacing the Knuckles and that's an extra $1100. I am also looking to see if I can bump up the power currently factory-rated at 315 HP and no I haven't had it on a dyno, yet. Any suggestions for adding power would be greatly appreciated.
Just go for the 6-piston fronts and 15" discs. The rears are basically there for decoration, so don't worry about putting much money there. If you want to drop a little weight with 2-piece discs, sure, but even that is overkill. The engine is a relatively easy fix. You'll need an intercooler, a drop-in air filter, a tuner and a tune. The first one, do right away. The stock intercooler kills the engine even when it's stock, so it definitely kills anything more than that. I'm not sure if anyone is tuning these yet or if there's a FP tune (which would be the HPP map). When the ECU's get cracked, these will be the guys to do it. They're awesome with Eco's and they have a 2024 HPP as a test mule https://emsinc-tn.com/.
6,497
8,425
Phoenix is working on these, they have an in house dyno ( and about everything else you will need) and they have experience racing them.
Tell them blacksheep sent you
343
348
So Cal
I'd put the intercooler way up on the list just because the stock one is so bad, but engine stuff isn't all that important to start. Job one is replacing every bushing on the car with either Polyurethane or a spherical.
Agree with intercooler if you’re after power. Add to that GFB DV+ blowoff valve. Helps response into boost considerably.
I chased more power with my Ecoboost including a bigger turbo but it didn’t deliver the power curve or impact I was looking for. So in retrospect I’d say if you’re after power the max I’d do is an intercooler, downpipe, BOV, drop in air filter and a tune. If that doesn’t do it for you this isn’t the right power plant for you. Those all had good returns but returns diminish after that while cost increases significantly.
And agree with above, sphericals everywhere you can especially RLCA, toe link, and toe link knuckle bearing. Huuuuuge improvement.
23
43
Nevada
Well, I have been out of town for a couple of months. Now that I am back I just ordered everything to do the Brembo upgrade for the brakes and the Ford Performance Mustang 2.3L Track Lowering Springs. Unfortunately for now there are still no options for power upgrades for the 2024 Ecoboost
