Gen1 70 Mach 1 SCJ Drag Pack Build Thread Profile - Gen 1 Mustangs
6,453
8,378
I worked at this place off and on for about 25 years,(days off from the FD) great folks, The owner has a 67 and a 68 Gt500 mustang, a Gt350 (69) clone Sunbeam Tiger and we've worked on a million cars there. Dyed in the wool Ford guys. this si a link tot heir project page, if you are interested.
The item 70 Mach 1 SCJ Drag Pack has been updated:
Update 2/28/21
Engine is home!
428 SCJ, 30 over 10.5:1 TRW pistons, Comp cams hyd flat tappet, Stock shafts & adj rockers, Steel end support stands added, Ebock RPM heads & intake,
PRW alum water pump, Canton 7qt T-Pan (8 qts with the oil cooler). 427 valve covers are temporary - I have a set of 428 Snake covers on the way.
Scheduling some time on the dyno for break in and set up. Also trying to decide on fuel system: stock Holley carb (735) or Holley sniper EFI....
More to come....
1,755
3-5 Years
Huntsville, AL
1,131
1,755
3-5 Years
Huntsville, AL
Several of my vintage race friends use Siebert. Very good carbs. It will probably be my next carb.
I have two carbs from SMI before he got main stream and super expensive. Sean is the original product engineer for JET Performance Products. He is a wealth of NA knowledge and he still answers his own phone.
6,453
8,378
Update 2/28/21
Engine is home!
More to come....
I think I'm sporting a semi..
Oct 2021
Slow going on the build. Time is a commodity that there is never enough of.
Had a minor setback by choosing an RPM intake for the engine.
It was a late discovery that an RPM intake and a shaker hood don't mix well.
The RPM sits 1 inch higher and 1 inch back compared to OEM and hood wants to hit the rear of the shaker scoop. (GRRR)
I didn't want the bulk of a cast iron CJ intake and fortunately, a friend had a really nice aluminum PI intake he was willing to sell.
Some hairline cracks were notices on the flywheel and I ended up having a new SFI wheel match balanced. (Say "no" to 50 yr old cast iron)
Rear leafs turned out be the originals and were in decent shape so they were disassembled, blasted, painted and reassembled with new hardware.
Same for the staggered shock plates and sway bar brackets.
This part was much less of a hassle than I had anticipated. Although, I'm still finding media in strange places :oops:
Finish is not concours, but it'll do.
The rebuilt (date code) 4:30 "N" case center section was sourced from Allen at 8 & 9 inch rearends.
Once that was installed it was followed by the axles and brake hardware.
Just need to tweak the brake fittings a bit then I can slide the whole assembly under the car.
Dash wiring is probably next
Oct 2021
Dec 2021
Rear is in and she's standing on all 4's again !
Aluminum Ford PI intake was swapped out to replace the RPM intake (interferes with shaker hood/scoop - who knew?)
Engine is T'd up for install - just need to bolt on the clutch & bell along with the exhaust manifolds.
After that its time to dive into wiring and brake/fuel lines....yay
