BMR 1.5inch lowering springs (SP068R)
51
38
Nova Scotia Canada
1.5" is a big drop and more in line with looks then handling. Would be better off with Ford P springs with the Konis
Noted. My dad has the p springs on his car and I find them a little bit rough. Do you have experience with these springs or just that 1.5 inch is a bit much for performance?
321
267
3-5 Years
25 min. to 1½ hrs. from Sonoma (ugh... traffic!)
With the car lowered 1-1/2" in the rear there won't be much room for suspension travel. You'll need to cut or replace the bump stops with shorter (firmer). You might find hitting the stops to be even rougher than those P springs. And the car will not handle at all well if riding on the stops in high g corners. Hard launches and rear squat might pose issues too.
