Boss Transmission/Clutch Issues Poll Discussion Thread
What brand clutch did you get?
McLeod RXT
Did it solve the high RPM lock out? Permanently? Temporarily?
Yes, permanently
If "permanently", how many track days do you have on the replacement clutch?
12
Thanks guys. Also saw on another topic that pufferfish likes the SPEC stage 1. So SPEC, RXT and RST seem to solve the lockout and low pedal problem. Anyone gone to an aftermarket clutch and NOT had the problems solved?
ace72ace
Zaino, I put that $hit on everything
1,242
71
Looking to resolve 2-3 lockout issue on my MGW equipped Boss.
McLeod RXT clutch kit and flywheel = problem solved?
I haven't tracked mine yet, but am preparing for that fateful day when the parasites - er I mean kids are not draining my wallet to subsistence levels =D
677
256
I hate to say it (and I have no experience with the torque limiters) but that is not going to cure the lockout issue. It's a clutch thing - RST is what finally cured it for me and I wish I hadn't wasted money on other things trying to sort it out.
ace72ace
1,242
71
Thanks for the feedback, I think I'd rather wait a while longer and fix it right way rather that try and go cheap. Summit has 4 pages of results when filtering clutch kits by model;
https://www.summitracing.com/search...013/make/ford/model/mustang/submodel/boss-302
Is the first hit on this list the one people in this thread have installed?
Manufacturer's Part Number:6912-25
Part Type:Clutch Kits
Product Line:McLeod RST Street Twin Clutch Kits
Summit Racing Part Number:MCL-6912-25
UPC:887753011282
TMSBOSS
7,573
5,308
Illinois
Yes, this is the cLunch kit I used. See the note about the flywheel.
Notes:For use with MT-82 transmission. Will not work with factory 9-bolt pressure plate flywheels. Crank relief must be 6.250" or smaller for correct disc to flywheel contact
I went with the lightened steel flywheel.
ace72ace
1,242
71
It's a secret... ;)
...he sent me a DM about team beefcake running 15% off sales - but they aren't right now. I wouldn't mind throwing one of the TMO vendors some business if the price is right.
10
11
Alberta
Add me to the list of those suffering the sinking clutch pedal on the occasional high rev shift. Happened to me again today as I was pulling on a newer Mach1 on a straight away. No issues when doing some normal driving or spirited...as long as I'm not up near red line.
4
2
Autocross
Birmingham, Al
This thread is now going on 11.5 years. What is the current conventional wisdom in terms of clutch model? For a long time it was McCleod RST. I've also seen Exedy mentioned, though not a specific model. Are those the two leaders?
Anything else I should know before I order a clutch kit? I'll also get a pilot bearing, throw out bearing, SS line. What else? Pulse ring?
