Boss Transmission/Clutch Issues Poll
Have you experienced any of the issues below?
  • Have you experienced shifting lock out upshifting in any gear?
    Votes: 150 57.7%
  • Have you experienced any shifting lock out downshifting in any gear?
    Votes: 57 21.9%
  • Have you experienced any grinding when shifting the car cold?
    Votes: 97 37.3%
  • Have you experienced any grinding when shifting the car hot?
    Votes: 59 22.7%
  • Have you experienced the clutch pedal partially sticking while shifting above 6,500 RPM's?
    Votes: 69 26.5%
  • Have you experienced the clutch pedal sticking to the floor while shifting above 6,500 RPM's?
    Votes: 46 17.7%
  • Have you experienced any of the above while using TracKeY?
    Votes: 76 29.2%
  • I have not had any shifting issues.
    Votes: 42 16.2%
  • I have not had any clutch issues.
    Votes: 63 24.2%
  • Have you documented any above issues with your dealer?
    Votes: 37 14.2%
  • Total voters
    260
This is good info as I am about to replace the clutch on my 13 Boss with 13K miles. I get locked out of 5th on the track and have decided enough is enough. So why the RST over the RXT? I also considered an Exedy from Kohr but couldn't decide on a single or twin disc. Exedy isn't cheap but after buying a lightweight flywheel the McCloud isn't either. So my question......go with a twin disc over single?
Get a twin disc - smaller diameter than the single disc results in less centrifugal force and positive disengagement. I run an RST... lockout problems solved.
Steve
How are you using your car? My Boss was a weekend track warrior and fun car. I installed the RXT and while it worked great on track it was a toggle switch on the street. It eventually broke-in and wasn’t too bad but it took the joy out of driving my car on the street hence my recommendation on the RST. Track only car I’d go the Exedy or RXT.
680
215
Rick,
it should be noted that McLeod does not recommend the RST for the Boss 302. According to McLeod, the organic lining can "balloon out" at high RPM. The Centerforce DYAD kit is a viable option. That's what I used to cure my High RPM issues. It's a really smooth clutch with a light pedal.
1,949
2,106
I am on my 3rd Transmission and 3rd Clutch in my Boss. Installed the Blowfish mount and that solved shift precision. Replaced the stock clutch with an RXT. The RXT failed and took out the second transmission.
Now have a twin plate Exedy that's been great, but the Tranny will get swapped for a Tremec this winter.
Aside from addressing the Cooling and Clutch/Transmission, the Boss has been remarkably robust -- over 12,000 hard track miles (180 hours) with just fluid and brake changes, plus PM on Front Hubs, Howe joints, etc.
Thanks for the replies. I thought hard about just going with the Tremec but since my transmission is, for the most part, fine it was worth trying the clutch option first. I have the race spec MGW already installed. I only drive my car on short trips during the summer. It will primarily be a track and hillclimb car (maybe 6-8 events per year). I am in the process of purchasing some serious track upgrades but the lock-outs really got me angry. I had the car for sale for the last two months and was going to get a 1LE Camaro or GS Corvette. I love the Boss but it needs a lot of upgrades (ie cash) to keep up with the competition. I decided to just bite the bullet, make some upgrades and enjoy the car.
TymeSlayer
3,787
2,741
Brighton, Colorado
Build date found on inside your drivers door: 12/11/11
Do you have skip shift disabled (2011/2012 owners only) YES
Have you replaced your transmission fluid? If yes what did you install? YES - Royal Purple Synchomax
Have you replaced your brake fluid? If yes what did you install? YES - Motul 600
Have you installed an aftermarket shifter? YES - MGW Race Spec
Have you installed an aftermarket shifter bracket? NO
Have you installed an aftermarket clutch line? YES
Have you installed an aftermarket clutch? If yes what did you install? YES Spec 2+
Have you tracked your car? Track, autocross or strip? Autocross and Track
If you've had any warranty work completed related to your clutch or transmission please describe as briefly as possible. N/A
Have you removed your clutch assist spring? NO
Do you own a Boss or GT? BOSS
550
Snowy North
Have you replaced your brake fluid? If yes what did you install? YES - ATE DOT 4
Have you installed an aftermarket shifter? YES - MGW RaceSpec
But the big question is....did ya get lip fungus from "The Flash"???
173
38
So how is the Exedy Twin doing for you?
Build date found on inside your drivers door: April 2014
Do you have skip shift disabled (2011/2012 owners only)? N/A
Have you replaced your transmission fluid? If yes what did you install? NO
Have you replaced your brake fluid? If yes what did you install? Castrol SRF DOT4
Have you installed an aftermarket shifter? NO
Have you installed an aftermarket clutch line? NO
Have you installed an aftermarket clutch? If yes what did you install? NO
Have you tracked your car? Track, autocross or strip? Track/HPDE
Do you own a Boss or GT? 2014 GT TP
Do you have skip shift disabled (2011/2012 owners only)? NA
Have you replaced your transmission fluid? If yes what did you install? DOT 4
Have you replaced your brake fluid? If yes what did you install? DOT 4
Have you installed an aftermarket shifter? MGW
Have you installed an aftermarket shifter bracket? No
Have you installed an aftermarket clutch line? No
Have you tracked your car? Track, autocross or strip? Yes
If you've had any warranty work completed related to your clutch or transmission please describe as briefly as possible. No
Have you removed your clutch assist spring? No
Boss
Build date found on inside your drivers door: 4/15/11
Do you have skip shift disabled (2011/2012 owners only)? Yes, No or NA No
Have you replaced your transmission fluid? If yes what did you install? Yes, Ford dual-clutch fluid per TSB
Have you replaced your brake fluid? If yes what did you install? Yes, Motul 600
Have you installed an aftermarket shifter? No
Have you installed an aftermarket shifter bracket? Yes, Blowfish Racing
Have you installed an aftermarket clutch? If yes what did you install? No
Do you own a Boss or GT? Boss
10
11
Alberta
Build date found on inside your drivers door: Dec 2012
Do you have skip shift disabled (2011/2012 owners only)? Yes, No or NA NO
Have you replaced your brake fluid? If yes what did you install? NO
Have you tracked your car? Track, autocross or strip? NO
Have you removed your clutch assist spring? NO (may try)
Almost 42,000 miles on the car.
