Gen1 LONG TERM PROJECT CAR Build Thread Profile - Gen 1 Mustangs
GB899
NO REGRETS
597
764
Nebraska
getting kind of frustrated with the 67... replaced the transmission output seal twice in one night now... still puking fluid at the tailshaft..
Any hints for a Tremec TR3550 seal replacement?
Any other causes for the leak?
6,452
8,375
Make sure the driveshaft is the correct diameter for the seal and that it doesn't have any grooves in it. You may also have to replace the tailshaft bushing (I'm not sure what scheme Tremec uses for this) but there is a trick tool that let's you remove the old one and install a new one without pulling the tailhousing off.
GB899, Don't think of giving up the ship just yet!!!!!.....You will reap the rewards of this journey one day and be thankful you took it!!!!!!!!.......I love the look of a 67/68 Mustang.....:hellyeah:......Quote of the day............" Faith is the bird that feels the light when the dawn is still dark".......................................................................
7,571
5,304
BS1 is spot on about the bushing. If the bushing is worn, the seal won’t have a chance. It will look good but will leak because the yoke is not centered and oil will get past the seal.
Another thing to check, although not common is the plug in the yoke. The plug sealing the opening on the joint side. It’s uncommon for these to leak but it does happen.
GB899
NO REGRETS
597
764
Nebraska
well after 3 new output seals we discovered that it was the yoke after all.. new yoke to show up today... old driveshaft is back in temporarily... yoke may be covered under warranty - they need to inspect it first... if not driveshaft may be a fraction of an inch too long.. ugh... hoping it is a defect... looked at the yoke and it doesn't look damaged...
7,571
5,304
Its not common, but it happens.
Good luck.
GB899
NO REGRETS
597
764
Nebraska
drove the 67 to a show and shine this chilly evening... still has the old driveshaft in... that car is a beast... hopefully will get the yoke swapped out and back to what it is supposed to be... This winters project will be the interior.. new seats & dash are the big pieces.. debating whether the backseat stays in... it's a fold down so I can put in a shelf without changing the look much... and lose a bunch of weight...
7,571
5,304
I’m with Bob. Stock all the way for the interior.
Be sure to replace all the padding in the seat cushions and backs. A good set of hog ring pliers go a long way over the cheaper kinds. Besure to post pics as the inside comes alive.
GB899
NO REGRETS
597
764
Nebraska
well.. I ordered some parts from Steeda for the old pony... shift arm & ball mostly... need to still order the seats and belts... it has been a bit wonky here since new years day.. medical stuff, but not me this time.. I am a better patient than I am a caretaker... I over do the hovering and anxiety part.. things feel like they are "normalizing" back to just chaotic... will hopefully have some real news to report this spring/summer.
8,522
8,583
But in the meantime Rob did make a killer sour cream raisin pie to share with his friends. Friendship means driving pies in a radius squared for his buddies. Chocolate pecan pie sounds good and I will be happy to sample two pieces this time my friend. Give my best to your wife and you do a good job hovering ................a little pie helped my knee surgery heal faster , ha.
