Gen1 CorteX Vintage Build: Project Hatemail Build Thread Profile - Gen 1 Mustangs
cortexracing
Supporting Vendor
42
138
This is the Build Thread for CorteX Vintage Build: Project Hatemail. Reply below.
Hey All, we wanted to start pulling the wraps off of some of our in-shop builds and figured we would start it off with a bag. You'll be able to read and follow along with all of our builds on our blog on the corteX website under "Customer Cars." The specific link for this one is.. https://www.cortexracing.com/blog/customer-cars-2/operation-hate-mail-8
Introducing Hate Mail, a LS7 powered '67 K-code car designed to take no prisoners. Read on in the blog and for now, enjoy some eye candy.
burkhart engine.jpgburkhart radiator.jpgburkhart clamshell.jpgburkhart side 2.jpgburkhart back1.jpgburkhart front2.jpgburkhart brake lines.jpgburkhart under car exhaust.jpgburkhart engine in.jpg
832
1,409
TX
What're you guys using for bulkheads in the hard lines? are those AN lines? 37 degree single flare or double?
cortexracing
Supporting Vendor
42
138
Any new updates guys? @cortexracing
Yep, should have a pretty sizable update coming soon. The car is currently largely stripped down for finish welding. So, even though we are cruising right along it doesn't "look" that much different than our last update.
We do have a new build thread that i will get posted here this week on another project we are working through.
~Chandler
41
25
Wyoming
View attachment 88806View attachment 88807View attachment 88808View attachment 88809View attachment 88810View attachment 88811View attachment 88812View attachment 88813View attachment 88814
Great eye candy. First, those beautiful spindles/uprights!
Criticism for the LS not because it’s Ford v Chevy. So am I horribly wrong the main LS advantage is compact heads and mass production cost benefits?
Yes it’s more expensive but the breathing is smashingly better, drivability over a wide rpm range much better, and more — in a well designed 4 valve engine. You’re already in high dollar tech with everything so a pushrod V8? Matt Farah once said of the LS that it gets in its own way. If response is a priority, he’s right. It’s a great engine with so much available power, doubtless. But really, for a long time, better has been accessible.
